Broken Cast Iron Flange
Discussion in 'Toilet Forum discussions' started by Armadillo, Oct 26, 2005.
  1. Armadillo
    Armadillo New Member
    Oct 26, 2005
    O.K. so this is another broken cast iron flange question. I have battling fathers on this one. My dad says.."Just call the plumber and have him put another cast iron flange. Better do it right." My father-in-law says..."Try this thing. It'll work just as well, and save you a bunch of money."
    This is the thing...
    http://www.siouxchief.com/PDF/887-pushTite-spec-sheet-7-04.pdf
    So I guess I'd like to try the Push-Tite as it will be much cheaper, and seems easy enough for me to do. I'm pretty handy, but I'm not going to muck around with molten lead and yokum and all that mess.
    There are two catches.
    1) The water leaked under the sheet vinyl a bit and discolored the white portions, and it doesn't seem to be improving with drying over the last 2 days. I would like to replace the flooring (from sheet vinyl to tile) one day. Unfortunately, the toilet didn't cooperate by leaking when I had the funds to do so. Will I need to mess around with re-adjusting the height of the flange when I do replace the flooring? If so, it seems like the Push-Tite would be easier since I could just remove the screws, pull it out..put in the subflooring/tile/etc., and put it back in flush with the new height. Is that too easy, or am I on to something here? OR...is there a way to get rid of the sheet vinyl discoloration?
    2) The hole in the subfloor is a bit bigger in diameter than the holes to secure the Push-Tite. So either I need to put the screws in at an angle, or I need to replace a section of the subfloor so I can make the hole smaller (probably not a bad idea since it got a bit wet with the leaking toilet.)
    So that's a few questions in one post...I'd really appreciate help with all of them.
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    flange
    If it's not too late, listen to your dad............
  4. PEW
    PEW DIY Senior Member
    If you are going to try and fix it yourself, I would first consider the following in place of the one you posted. I personally feel it is a much better product. However, either will require your wire brushing the inside of the pipe very clean. In fact it is best to use a wire brush on a drill. You will also want to be sure it will not raise the top of the flange too high.
    http://www.oatey.com/apps/catalog/showskus.asp?ctg=11&subctg=3&prodgrpid=363
    Terry has recommended the cast iron version, but you will probably find it hard to locate. The PVC ones have worked fine for me.
    Paul
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    flange
    If you rely on screws put in on an angle, I don't think you will have a good installation. It's like a cobble job.
    Don't like set screws either.
    It may be cheaper now, but it might cost you more later........
    Your dad is still right........
Similar Threads: Broken Cast
Toilet Forum discussions Toilet flange - cast iron and broken lead closet flange Nov 8, 2015
Toilet Forum discussions broken bolt on cast iron toilet flange Mar 25, 2013
Toilet Forum discussions Broken Cast Iron Flange too Deep for insert replacement Sep 28, 2011
Toilet Forum discussions How do I remove broken cast iron closet flange from PVC pipe Aug 31, 2010
Toilet Forum discussions crooked and broken cast iron flange in concrete slab Jan 2, 2010
