Broken 1" pvc supply line help
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by JeffH, Oct 6, 2007.
  1. JeffH
    JeffH New Member
    May 21, 2006
    California
    Yesterday my neighbor's son broke the 1" PVC main supply on the house side of the meter. Unfortunately, because of his hardscape I can only expose about 3 feet of line. I installed a 1" compression fitting so they could at least have water through the weekend. No leaking after 24 hours of full pressure. Can I keep this as a permenent solution? It's eventually going to be buried. Short runs of 1" sched 40 doesn't give you much play room for glued connections. What would you do? Insight needed.
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Replace the broken section, use couplings to fit to the rest of it. If you're unsure of something don't bury it.
  4. jimbo
    jimbo Plumber
    `That compression coupling should be OK . The other 2 choices would be a slip-fit slide coupling, or a union.
  5. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Should be? That's not too reassuring. :D
  6. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Four 90's................
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Compression fittings are the best way to repair PVC pipes. Before they came along, you could use 4 elbows with short pieces of pipe. That worked, but were really ugly. I fixed a couple of sprinkler lines that way and covered them with dirt ASAP! The compression couplers are not only effective, they look a lot neater and are bunches easier to use.
  8. JeffH
    JeffH New Member
    May 21, 2006
    California
    Thanks folks...
    48 hours at full pressure without leaking before burying. My nieghbors are truley grateful and I feel good for helping out. Thanks again for the input! You folks and this website are great!
  9. hj
    Pvc
    Where was the pipe that he could break it? PVC is only supposed to be underground, not brought up through the surface and exposed where it could be damaged.
Similar Threads: Broken supply
Plumbing Forum, Professional & DIY Advice broken water supply to washer - I stripped the threads! Brand new! Nov 27, 2012
Plumbing Forum, Professional & DIY Advice Broken water supply to house Nov 26, 2012
Plumbing Forum, Professional & DIY Advice Broken sanitary tee in block Jan 29, 2017
Plumbing Forum, Professional & DIY Advice How to fix broken bolts from the sewage basin lid? Do i need a new basin? Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Delta Faucet Question (is it broken?) May 23, 2016
