Brine tank size
Discussion in 'Water Softener Forum, Questions and Answers' started by amateurplumber1, Mar 22, 2013.
  1. amateurplumber1
    amateurplumber1 Member
    Mar 10, 2013
    Here
    This may seem like a weird question, but shouldnt all 18x33" tanks hold the same amount of salt?
    So far, just looking around, one website i can buy from has the capacity listed as 375 lbs, another website has the capacity listed as 325 lbs, and another site has the capacity listed as 240 lbs. I would think the largest one would be the best, but I have no experience with these things so I'll defer to you. Any reason for the discrepancy?
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Some are round, some are square, some have a taper.
  4. amateurplumber1
    Mar 10, 2013
    Here
    All of the ones I'm talking about are round, though. 135 lb difference between most and least is surely not just a taper?
  5. Gary Slusser
    Retired
    I suggest that you don't fill any size/shape salt tank because eventually you will forget to check the salt level and run out. When that happens you must regenerate numerous times with whatever your salt dose is or, increase the salt dose to 15 lbs/cuft of resin and do two manual regenerations with no water use during or between them and the set the dose back to what it was. If you run low or out and don't do those regenerations, your resin will never be fully regenerated from then on.
    So a better way is to buy like 5-6 bags and add 1 or 2 bags to the tank leaving a couple spare bags next to the softener. Then check the level each week and add as needed. That way you will see if there is too much water in the salt tank, meaning there is a problem and you'll usually prevent bridging.
    An 18" x 33" round that doesn't have a safety brine well etc. will allow filling all but to the rim, with a safety brine system, only up to the elbow overflow that holds the well in the tank so it will hold less salt. And then the type of brine pick up tube or a salt grid could change the volume too.
Similar Threads: Brine tank
Water Softener Forum, Questions and Answers 9100sxt won't refill brine tank Jan 26, 2017
Water Softener Forum, Questions and Answers Fleck 5000 and Brine tank question ( newbee ) Jan 20, 2017
Water Softener Forum, Questions and Answers Fleck warranty question on brine tank Nov 7, 2016
Water Softener Forum, Questions and Answers Brine tank filling during brining Sep 22, 2016
Water Softener Forum, Questions and Answers Brine tank, 10 years in use .... Apr 21, 2016
