Brine Tank Safety float setting
Discussion in 'Water Softener Forum, Questions and Answers' started by farmboy101, Jun 6, 2010.
  1. farmboy101
    farmboy101 New Member
    Apr 17, 2010
    Vancouver Island
    I am curious to know if the lower o ring needs to be set somewhere on the shaft. The upper one needs to be set so its just below the overflow fitting but the lower one was set on the bottom of the shaft. The float moves up and down freely but should the float rest at the bottom of the shaft and rise up and down with the water level or should it be set higher up so it only hits the top o ring in the event of a malfunction?? Brine Float 002.jpg Brine Float 003.jpg Brine Float 001.jpg Brine Float 004.jpg
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Shoot the thing now before the headaches start....
    When I come across this kind of float assembly I put in a request to change it out with the 2310 safety float assembly as I have had next to no problems that 2310 plastic or brass.
    Yes brass fell to the salt air but out side of that challenge .. no problems.
    The one that you have has in my view to many things to go wrong and be a real pain ...
  4. farmboy101
    Apr 17, 2010
    Vancouver Island
    Curious to know what part is crap? All of it ? :confused:
  5. Akpsdvan
    Dec 29, 2009
    Alaska
    The bottom part has its challenges, some times not seating right. If there is some salt or any thing else that gets in and around that rubber disk that can cause it not to work right.
    The float rod can be a challenge, if there is a problem with it not filling trying to push down on the whole assembly could break the rod as it is of a plastic ..
    It is much like the cheap Sears GE softener float... if any thing goes wrong they have made it cheaper to replace than fix.
  6. farmboy101
    Apr 17, 2010
    Vancouver Island
    OK, I will look for a 2310 but will have to use this until then. I thought it was kinda frail looking when I took it out. Thanks
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    There is a site that we all know that people buy and sell.....
    180502635225
    is a lead as to the type that I am talking about.
  8. farmboy101
    Apr 17, 2010
    Vancouver Island
    Thanks Akpsdvan, I never even thought about looking there ;)
  9. Akpsdvan
    Dec 29, 2009
    Alaska
    That name is kind of like the Dark Lord who's name we do not speak of..... :D
Similar Threads: Brine Tank
Water Softener Forum, Questions and Answers 9100sxt won't refill brine tank Jan 26, 2017
Water Softener Forum, Questions and Answers Fleck 5000 and Brine tank question ( newbee ) Jan 20, 2017
Water Softener Forum, Questions and Answers Fleck warranty question on brine tank Nov 7, 2016
Water Softener Forum, Questions and Answers Brine tank filling during brining Sep 22, 2016
Water Softener Forum, Questions and Answers Brine tank, 10 years in use .... Apr 21, 2016
