Brine tank full of water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by whatnow53548, Dec 6, 2008.
  1. whatnow53548
    whatnow53548 New Member
    Feb 19, 2008
    I have a Fleck 5600SE valve and when my softener finishes regenerating the brine tank ends up being about half full of water. Any idea what would be causing this.....shouldnt the amount of water in the tank be lower than the salt level? thanks for your help.
    bob
  2. Gary Slusser
    Retired
    The amount of water put back in the salt tank at the end of a regeneration with a 5600 valve is always the same volume in gallons. The volume/level of salt is always being reduced because the salt is dissolved into the water that is then sucked out of the tank as brine during the brine draw/slow rinse part of the next regeneration.
    The salt displaces the water so there is no way to say if there is too much water in the tank by marking the water level and doing a manual regeneration and checking the mark. So IOW both the salt level and the water level will vary constantly.
    If the softener is working right, producing 0 gpg soft water from one regeneration to the next consistently, there's nothing wrong. If the water level consistently increases the water isn't being all sucked out and there is a problem and you'll get harder water until the softener isn't removing any hardness.
  4. whatnow53548
    Feb 19, 2008
    Ok, the water level does not increase.....it is high enough in the tank so that if I add 100 pounds of salt the water is still above the salt level. So from your answer am I correct that there is not a probem since I am getting soft water? Thank you for your help, it is very much appreciated.
    bob
  5. Gary Slusser
    Retired
    Don't put enough salt in the tank to make the water rise up to and lift the float or overflow on the floor and you're good to go as long as you always have soft water between regenerations. You're welcome.
Similar Threads: Brine tank
Plumbing Forum, Professional & DIY Advice Quick question about water softener. Brine tank is soapy. Is that normal? (with picture) Oct 18, 2014
Plumbing Forum, Professional & DIY Advice Water Softener Brine Tank Overflowing Dec 7, 2008
Plumbing Forum, Professional & DIY Advice Brine tank hose diameters make women upset... Oct 8, 2008
Plumbing Forum, Professional & DIY Advice Water Softener Brine Tank Odor Jul 7, 2007
Plumbing Forum, Professional & DIY Advice sink tailpiece with bung for RO filter brine water. Quiet. Jan 31, 2013
