Slinger56
Hello, I recently replaced the bottom distributor on my GXSF27E01 GE softener when I started noticing beads in my no-longer-soft water. Luckily I caught it in time and only a couple of my faucet aerators were affected. I proceeded to replace the resin and the O-rings from the valve to the tank and the turbine meter (whose blades were totally gone), and refilled the resin tank with 3/4 cubic foot of beads. I was told by the supplier that the beads were already fully charged and ready to soften the water, but the water still wasn't soft even after a regen. Checking under the lid when it got to "service" I noticed there was brine covering the salt and it was about 2 feet deep. I then cycled the valve manually and it seemed that all the positions did what they were supposed to do, except during the brining stage the water level in the salt tank was coming UP, not going down. I took the venturi and nozzle assembly apart and cleaned everything and it looked good. I also removed the valve cover to check for beads inside there, but found none. Putting it back on I noticed two adjacent ribs next to one of the screws had small cracks, but other than that the cover looked sound. Any ideas what I should check next? Thanks for the help!!
