Briggs tank replacement
Discussion in 'Toilet Forum discussions' started by Bonesy, Jan 5, 2006.
  1. Bonesy
    Bonesy New Member
    Jan 5, 2006
    Hi,
    My first post here. I have a briggs toilet that developed a hairline crack along side the tank. I figured I could just replace the tank. I tried Lowes and Home Depot but neither carried Briggs toilets. The associate there said I might have to replace the whole thing because just replacing the tank may lead to leaks. I don't know how to find the model # of the toilet but it looks fairly generic in shape and size, but what do I know. Anyways, is it true that I would need to replace the bowl as well? I tried to locate Briggs tanks on the web with absolutely zero results and that was going through the official Briggs website.
    Thanks for reading,
    Andrew
  2. jadnashua
    It may be hard to find a compatible tank unless it is a fairly new toilet. If you could find an exact match, it shouldn't be a problem. You probably would want to use new washers and seals, though, and those might be hard to find as well (unless the model is still being made). While you are at it, replace the supply line and the guts, those should only add maybe $10, and why put the old stuff back in. Last, though, repair parts are often pretty expensive, and it may just make more sense to replace it with a new one...lots of people here, including myself, like the Toto brand - the largest toilet manufacturer in the world (they have a US factory in Georgia, along with numerous places around the world).
  4. Lancaster
    Lancaster New Member
    Nov 7, 2005
    Please post the tank number,cast into the inside of the tank.Should be a four digit number "4xxx" with possibly a letter for the color.
  5. Bonesy
    Bonesy New Member
    Jan 5, 2006
    reply
    The number I found was 4430 also said Briggs Proflo.
  6. Lancaster
    Nov 7, 2005
  7. steve_t
    steve_t New Member
    Jan 5, 2006
    briggs 4930 tank cracked
    hola,
    i too have a crack on my briggs tank. i was unsuccessful in finding any info on briggs website.
    i appreciate any help you can provide.
    briggs tank: 4930-c
  8. Lancaster
    Nov 7, 2005
    The 4930 tank is obsolete.It was a 3.5 gallon flush.The current 4430 tank is 1.6 gallon flush and though it would likely fit,it will not flush correctly with the old style bowl.This has been verified by someone who tried it against my advice.
    Not much alternative except to buy a whole new toilet.
  9. steve_t
    steve_t New Member
    Jan 5, 2006
    thanks for the prompt response lancaster
    you confirmed my worst case scenario. how do i determine the rough-in size without removing my old toilet?
    also, is the toto ultramax still the best option for the money?
  10. hj
    size
    Measure from the actual wall surface to the center of the rear bolts holding it to the floor. If it is more than about 11 1/2" you can use a conventional 12" rough unit.
  11. steve_t
    steve_t New Member
    Jan 5, 2006
    thank
    thanks for explaining how to measure the rough-in.
    anyone interested in a white briggs tank cover?
    :D
  12. MBryga
    MBryga New Member
    Apr 10, 2008
    Briggs Tank Cover Replacement
    Hi,
    I've got a Briggs 1.6gpf elongated toilet that is missing it's tank cover. I would appreciate any help in identifying the model and locating a replacement tank (or just the tank cover). The only other identification does not fit with what is described on this thread - "FFR 5 1986" upside-down on the inside back wall.
    Thanks.
  13. hj
    number
    Is probably FEB 5 1989 the date it was made. Most areas have a plumbing supply company that accumulates tank lids from cracked tanks. Call around to the various ones and see if they know it there is one in your area. Take the old lid, or a cardboard cutout of the tank's top and use that to find an equal or compatible lid.
  14. tototalitarian
    tototalitarian New Member
    Feb 28, 2008
    California
    Been there , done that with Briggs
    I just replaced my Briggs with two Toto Drakes. Damn, what a site. Gets the job done.
    Butt, I had a hairline crack when I tightened down the inner bolts of the top tank to the bottom tank.
    Solution,
    buy JB weld an metal epoxy.
    clean the area where the hairline crack starts and finishes, and go beyond that crack,... use the epoxy and but some on the crack. Install it back on the tank and then hit it with silicone.
    Presto Changeo. You are back in business. It will work.
    Lets us know what you do.
  15. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  16. mbyoungster
    mbyoungster homeowner
    Nov 3, 2010
    new jersey
    Yikes! Rusted connector bolt is fused to the porcelain tank
    I am replacing the inside components to a Briggs 4930 toilet tank. I shut off the water, drained the tank and found that the bolts that connect the tank to the base are rusted. The first bolt fell apart and was easy to remove. The second bolt would not budge. I could not turn the nut on the outside bottom of the bolt and was able to get in between the base and the tank and sawed the bolt.
    I now have the tank off the base but I am unable to remove the bolt stub. On the inside of the tank the head of the bolt was completely rusted and fell apart, the bolt shaft remains in the hole.
    I created a little cup out of plumbers putty and have soaked the bolt stub in WD 40, I tried diet coke, and I am currently trying CLR (calcium, lime, rust). The bolt stub still will not budge and I am afraid of cracking the tank. It is a discontinued model and I really don’t want to replace the whole toilet at this point.
    I think the answer lies in dissolving the rust but I am out of ideas. Does anyone have any suggestions on what to do next?
  17. Cookie
    Cookie .
    Oct 7, 2005
    I used to do my own body work on my cars because I couldn't afford to pay anyone, so I used Naval Jelly, which might work; also, you could try a penetrating oil because it will penetrate into the threads. WD 40, won't work because it is not a penetrating oil.
  18. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    WD40 is the wrong product to use. The best penetrating fluid for rust is PB Blaster available at most hardware and automotive shops. One might question the wisdom of refurbishing a Briggs toilet, but if that is your desire, then go for it. I won't promise the PB Blaster will solve the problem, but it will be better than WD40.
  19. hj
    Put a screwdrive against the bottom of the bolt and gently tap it upwards.
  20. mbyoungster
    Nov 3, 2010
    new jersey
    Uuggh Now the outside bolt to the flush valve will not budge.
    Thank you for your replies. I went ahead and rolled the dice so to speak. I settled the tank upside down on a one inch foam pad with a few layers of cardboard underneath to absorb as much shock as I could and started with a thin metal drill bit and very slowly drilled through and then increased drill bit size until I was able to drill through the bolt.
    I know it was risky because one small error and the tank could have cracked very, very easily.
    Well onto my next problem.
    The large plastic bold on the outside bottom of the tank that holds the flush valve piece will not budge.
    It looks like it is glued to the bottom of the tank.
    Does anyone have any suggestions on how to dissolve the glue or remove the plastic bolt. I am still afraid of using force, I know how delicate the porcelain is.
    Thanks all....
  21. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Cut the nut in 2-3 places so it will come off in pieces.
Similar Threads: Briggs tank
Toilet Forum discussions Briggs R-7240 Tank Sep 29, 2011
Toilet Forum discussions Briggs Toilet Tank cracked Jul 27, 2010
Toilet Forum discussions Replace tank on older 1.6gpf Briggs toilet or buy new toilet? Feb 26, 2010
Toilet Forum discussions Cracked BRIGGS 4930 D Toilet tank???? Jun 1, 2005
Toilet Forum discussions Replacing old Briggs 7340 rear outlet floor/wall mount Sep 12, 2015
