Breaking vacuum on frostproof hose bib
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by SmileyMn, Nov 5, 2008.
  1. SmileyMn
    SmileyMn New Member
    Nov 5, 2008
    I had to replace my outdoor hose bibs due to broken threads.
    I installed the new frostproof sillcocks as I live in Mn where it's cold.
    On of my new sillcocks doesn't have the best angle so I'm not sure if water drains out of it when the sillcock is closed.
    I have an easily accessible shutoff valve for it in the mechanical room of my basement.
    Just for my own sanity, I want to shut off the water to the hosebib in the winter - even though it's frostproof.
    My question is that the new hose bib has an integrated vacuum (I imagine to prevent backflow).
    How can I easily break the seal on the hose bib so I can drain the water through the shutoff? The water is shut off and the tiny drain in the bottom of the shutoff is open and the sillcock is open yet the water isn't draining out of the line.
    Is there an easy way to do this?
    Thank you!
  2. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    It sounds like you have a negative that will trap water ... not desirable. If I were you, I would just shutoff the water inside the house at the valve and open the sillcock.
    If it breaks, no big deal. Put a new one in next year with the proper pitch so it self drains.
  4. SmileyMn
    SmileyMn New Member
    Nov 5, 2008
    Happy Friday!
    I checked last night with a level and I do have the slope correct. When I shut off water outside, it is draining the pipe.
    It's a 12" frostfree hose bib with anti-siphon.
    The anti-siphon feature is a cap on top of the hose bib.
    The bib is made by Homewerks and is from Home Depot.
    Their is a brass threaded cap which is part of the anti-siphon.
    When I unscrew it, there appears to be some type of plastic washer or gasket underneath. Does this unscrew?
    What I'm trying to find out is how to momentarily defeat the anti-siphon feature of this hose bib to break the vacuum and drain the water from the hose bib to the shutoff in the basement.
    I looked inside the open bottom part of the sillcock and there is no sleeve or post which would break the vacuum - I think it must have to do with the brass threaded cap and parts underneath in the top of the bib.
    Thank you!
  5. Howard Emerson
    Howard Emerson I teach guitar:You call that a job?
    Apr 28, 2008
    Huntington Station, NY
    I bet if you took a hair dryer, or some other 'safe' heat source and applied it to the exposed pipe inside the basement, it would drain off once you equalized the vacuum by expanding the air that's in there, right??
    Calling Mr.Wizard........
  6. Terry
    Aug 17, 2004
    If it's a frostfree bib, then it's designed to be worry free.
  7. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    It does unscrew as I had to take mine apart to fix a plastic burr that made it leak.
    But... That is not where the check-valve is located.
    At the back of the valve there is a check valve that is part of the seat.
    I would not worry about it as long as its a 12 inch one and not one of the short 8? inch ones you will be fine since the insides are heated by the house.
    If you are still worried you could go buy one of those small foam faucet covers that goes on the outside.
    PS: Don't you love yesterdays snow ;)
Similar Threads: Breaking vacuum
Plumbing Forum, Professional & DIY Advice What to do to increase GPM without breaking the bank? May 21, 2016
Plumbing Forum, Professional & DIY Advice just broke my toilet trying to fix it :( overflowing => breaking the water fill valve Mar 13, 2014
Plumbing Forum, Professional & DIY Advice Settling Soil breaking underground water connections Sep 6, 2011
Plumbing Forum, Professional & DIY Advice Breaking up concrete... Jun 21, 2009
Plumbing Forum, Professional & DIY Advice unscrewing old pipe without threads breaking Mar 28, 2009
