Breaker tripping
Discussion in 'Electrical Forum discussion & Blog' started by rayh78, Jul 12, 2013.
  1. rayh78
    rayh78 Member
    Sep 15, 2008
    Colonial Heights, Virginia
    Have a rental property. Tenants complained about a breaker tripping once or twice a day.
    Breaker feeds living room and ceiling light.
    When this happens the light is not on and only two outlets in use. Floor fan and then TV and stereo.
    Anyway I went over and replaced the breaker and both outlets since I had them out to inspect for any burnt wires.
    But everything really looked fine. Did I miss anything?
    If it happens again can I assume it is a problem with their newer flat screen TV, the stereo or fan?
    Any suggestions on anything else I could have checked?
    Thanks
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    If they have a Surge Protecting Power strip, It could be bad.
    They are made to Short Out to protect, and sometimes they may not blow their own breaker like they should.
    A Voltage Measurement would tell if you have low voltage.
    Good luck.
  4. jadnashua
    It would take a really humongous TV and stereo system to overload a typical 15A breaker...it's unlikely that's the problem.
  5. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    Can't really tell what the problem is based on what you said but I agree with Jim, you should easily be able to run all the stuff you mentioned on a 15A circuit.
    The chance that it is a bad breaker is the least likely unless it is an AFCI breaker.
  6. rayh78
    rayh78 Member
    Sep 15, 2008
    Normal 20 amp breaker.
    Know if everything is working ok their stuff should not overload.
    But what else could it be. How to troubleshoot?
  7. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    There may be more outlets wired to that breaker than you think.
    What you say is on a 20 amp breaker should not come close to tripping it.
    If you have a shorted MOV in a Device Protector it could draw more current than normal, but it would trip the breaker all of the time.
    Is your voltage correct ?
  8. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    If you are doing work like this you obviously have an amprobe. What is the actual load? Not that it is close to overloading, but it is a place to start.
  9. rayh78
    rayh78 Member
    Sep 15, 2008
    reading 121 volts
  10. Speedy Petey
    Jun 16, 2007
    NY State, USA
    The main purpose of an amprobe is to read amps.
  11. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Is that the reading at the Breaker or at the Load ?
    Measuring at both ends will give you the voltage drop from the load to the source. That can test for a loose connection.
    As mentioned a Amp Probe would be handy.
    Everyone should own a clamp on, If they are going to play with electricity.
    Don't forget the PPE.
    Is the breaker still tripping ?
    Be careful playing with electricity.
  12. rayh78
    rayh78 Member
    Sep 15, 2008
    Busy on another project until I get back over there next week. But the 121 volts was at the outlet. And do have a clamp on my Fluke meter, just did not think to check at the time. Was not tripping often.
  13. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Would there happen to be a window air conditioner in use ?
  14. rayh78
    rayh78 Member
    Sep 15, 2008
    No ac. Nothing else I could tell on that circuit. Just a ceiling light not used when breaker tripped. And a small floor fan, TV, cable tv box and small stero.
    Dealing with a few other things. Will try to follow up and get over there to check the amp draw. And maybe take out a few more outlets to look for any burnt wires in boxes for lack of anything else to check. They did have one outlet that had recently been used for their computer, but said all of that was unplugged when this started.
Similar Threads: Breaker tripping
Electrical Forum discussion & Blog tripping breaker Jan 25, 2012
Electrical Forum discussion & Blog aluminum supply to sub panel - breaker tripping/wire heating Oct 5, 2010
Electrical Forum discussion & Blog Pool tripping GFCI breaker Aug 4, 2009
Electrical Forum discussion & Blog Circuit breaker keeps tripping Mar 28, 2009
Electrical Forum discussion & Blog Main Breaker Tripping Jan 8, 2009
