Breaker tripping
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Ben47, May 6, 2013.
  1. Ben47
    Ben47 New Member
    May 6, 2013
    Virginia
    While watering my plants the breaker to the pump will trip at various times. It has happened four time over a period of 3 days. I have a Goulds Bruiser submersible pump, Model 7SB07422C and a 50 gallon tank. The pressure switch is set to come on at 40# and go off at 65#. It cycles at about 33 sec- 15 sec on, 18 sec off (which seems fast to me) with the hose bib putting out about 3/4 volume. What things could cause the breaker to trip?
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Running for 15 seconds and off for 18 seconds is what is causing the breaker to trip. That is very fast and probably means you tank isn’t holding the 12-14 gallons it should. The bladder in the tank is probably bad, and that is also caused by cycling the pump on and off. Pumps like to run 24/7. Cycling on and off destroys everything in a pump system.
  4. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    The windings in the motor are overheating and eventually the motor will quit. Like valveman said, it sounds like the bladder has gone bad in the tank. Time for a new tank....
  5. Ben47
    Ben47 New Member
    May 6, 2013
    Virginia
    Thanks. Both the pump and tank are only 6 months old and have been used rarely as the house is still being built. Very strange.
  6. VAWellDriller
    VAWellDriller Member
    Sep 8, 2012
    Mud rotary well driller, pump installer
    Richmond, VA
    All should be under warranty then....call the installer back.
  7. valveman
    Mar 15, 2006
    Lubbock, Texas
    Even with a fairly new tank the bladder gets lot of abuse from the pump cycling on and off. And 2 wires motors are the worst for tripping a breaker when they cycle on and off too much.
  8. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    If you have a temporary electrical service for your house being built, you may just have excess voltage drop.
    A volt meter and amp probe will show you the problem. The breaker could be to small for the motor if the voltage is correct at the pump motor.
    Or the wire gauge is to small for its length.
    What size breaker and wire are you using ? What voltage are you using ?
    Good Luck.
Similar Threads: Breaker tripping
Pumps and Tanks Well Forum & Blog. Water is life. Pump breaker tripping Jan 16, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure dropping, breaker tripping Oct 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Cistern pump tripping breaker. Jul 1, 2016
Pumps and Tanks Well Forum & Blog. Water is life. well pump tripping breaker Aug 10, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Tripping Circuit Breaker Aug 5, 2014
