breaker questions
Discussion in 'Electrical Forum discussion & Blog' started by rbig, Mar 2, 2013.
  1. rbig
    rbig New Member
    Jan 28, 2008
    Florida
    I have a Siemans 200 amp panel coming into our house. It gives us 240/120vac.
    It has 5 blanks. Total of 8 blanks, 3 are occupied. This leaves me 5 blanks.
    Do I have to use Siemans breakers? Or, can I go to Home Depot or Lowes and get breakers there that will fit this panel?
    What do I need to tell Lowes or Home Depot to get the right configuration of breaker (I do have the Siemans model # of the entry panel).
  2. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    So, are you putting the breakers in yourself? There should be a large label inside the panel telling you exactly what kind of breakers
    you can use in it. The electrical codes say you have to use those.
  4. rbig
    rbig New Member
    Jan 28, 2008
    Florida
    Yes. I'll check and list those. Thanks for the info.
  5. hj
    My experience with Siemens is that they do not use "universal" breakers. Lowes carries Siemens but whether they have the model you need is something you would have to check on.
  6. Norcal01
    Norcal01 New Member
    Aug 16, 2008
    Siemens bought ITE & renamed them, ITE breakers do fit a lot of other makes and the vice-versa, BUT just because they do fit, does not mean it's OK to do so, UL does classify some manufacturers breakers to be used in competitors panels but you need paperwork to do so. IMO it's better to use the same make as the panel, then to use another make, Lowes handles Siemens so should be easy to find.
Similar Threads: breaker questions
Electrical Forum discussion & Blog Breaker questions Aug 10, 2007
Electrical Forum discussion & Blog Installing an AFCI breaker Jan 5, 2017
Electrical Forum discussion & Blog 20 amp breaker trips Nov 8, 2016
Electrical Forum discussion & Blog Running a 36amp load on a 40amp breaker Sep 15, 2016
Electrical Forum discussion & Blog 240v breaker serving two heaters Sep 13, 2016
