Breaker keeps tripping
Discussion in 'Electrical Forum discussion & Blog' started by Ryan1978, Oct 22, 2007.
  1. Ryan1978
    Ryan1978 New Member
    Oct 22, 2007
    Hello all,
    Long time reader, first time poster.
    Here's my situation. I have a branch 20A circuit coming to junction box "A" from the breaker panel. When the breaker is switched on, everything is ok. When I wire nut the hot and neutral wires from box "A" to the leg going to box "B," I flip the breaker and it stays on. The exposed wires at box "B" are hot.
    Now, as soon as I attached the wires at "B" to the receptacle and flip the breaker, it trips. On the chance that I had a bad outlet, I swapped it with a new one and it happened again. What in the world is going on???
    Thanks a lot for your help!
  2. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    It's a dumb question, but... both of them?
  4. 480sparky
    480sparky In the Trades
    Oct 8, 2007
    Electrical Contractor
    How are you attaching the wires to the receptacle?
    Black to brass, white to silver, and green/bare to green screw?
    Are you installing the recep back into the box? Is the box metal?
  5. frenchelectrican
    frenchelectrican Electrician
    Jun 16, 2007
    Master Electrician
    NE Wis / Paris France { In France now }
    i am more leaning to pitched wire in the box when the repecale is pushed back in it will trip the breaker as the OP stated that he left the wires open on the "B" box it was fine but after he installed the repetcale and push it back in somewhere a short do happend there.
    few case senicearo's
    nicked wire insluation
    one of the device screw is touching the wire
    ground wire touching hot wire in back of the box
    those items you have to check very carefully for any nicks , pitched wires and the way the wires fold in the box after you installed the device in there
    once you see it then reloacated the wires a little to prevent anymore concat there
    Merci, Marc
  6. Ryan1978
    Ryan1978 New Member
    Oct 22, 2007
    Well, obviously just the black is hot:D
    Sparky, I've done all that you said. The box is plastic, but I didn't reinstall the outlet anyway.
    To show that I'm not crazy (I'm trying to convince myself at this point), I've attached a picture showing the wires at box "b." Sorry for the poor quality, but you should be able to make out the black and white wires as well as the light on the tester. As soon as these are connected to the receptacle, the breaker trips.
  7. 480sparky
    Oct 8, 2007
    Is that another set of wires I see attached to the receptacle? If that's the recep you're putting the wires onto, you've got a short somewhere else down the line.
  8. Ryan1978
    Ryan1978 New Member
    Oct 22, 2007
    All I can say is I'm quite embarrassed:eek:
    Those wires did go downstream to another outlet I installed at the other end of the island. Of course, there's only one cable in that box so I couldn't have possibly screwed up anything there...right? Apparently I was working past my bedtime on that one and wired both the black and white to the brass terminals.
    Thanks for your help everyone.
  9. snafflekid
    snafflekid Electrical Engineer
    Apr 23, 2007
    Electrical Engineer
    Is that the glow from the wires overheating? :p
Similar Threads: Breaker keeps
Electrical Forum discussion & Blog Circuit breaker keeps tripping Mar 28, 2009
Electrical Forum discussion & Blog Our dishwasher overflowed and now the 220 breaker on stove keeps going off, when we t Jul 14, 2008
Electrical Forum discussion & Blog Installing an AFCI breaker Jan 5, 2017
Electrical Forum discussion & Blog 20 amp breaker trips Nov 8, 2016
Electrical Forum discussion & Blog Running a 36amp load on a 40amp breaker Sep 15, 2016
