Breaker / Fuse Protection LG LMU369HV
accesspro
DIY Junior Member
escondido,ca
I need to provide a branch circuit for the unit above.
Specs:
208-230/60/1
MOV 25 A
MCA 16.8 A
Cooling Rated Amps - 18.6
Heating Rated Amps - 19.0
Compressor A 12.1
Fan Motor A 1.1
What size branch circuit should i install?
What size running protection/disconnect should i install?
Do I need to install a receptacle near the unit ?
TIA
Bob
The installation manual typically lists the required electrical cable size required. You sure on that model number? It doesn't show up on the LG website.
