Breaker did not trip
Discussion in 'Electrical Forum discussion & Blog' started by edstevn, Nov 4, 2008.
  1. edstevn
    edstevn New Member
    Oct 27, 2008
    I had a breaker that did not trip. There was a loose connectionin on a lug, the lug had a darkened color due to the arcing which produced heat. The question I have is why did the breaker not trip?
  2. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    Is it a Federal Pacific Stab-Lok panel?
    A loose lug on the breaker could have been a contributing factor.
    Now the breaker needs to be replaced.
    If it was a high amperage breaker, there could be enough heat to cause discoloration on the lugs but not trip due to lack of enough amperage sensed inside the breaker.
    Many possibilities
  4. jimbo
    jimbo Plumber
    Was there a short circuit which SHOULD have caused the breaker to trip? A loose connection can arc under normal current draw. The breaker does not see this as a fault which it should trip/
  5. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    A loose connection can only reduce the current in a circuit, so it's possible there really was not enough amperage to trip the breaker.
    In this case power that is supposed to go into the load goes into heating the bad connection.
  6. edstevn
    edstevn New Member
    Oct 27, 2008
    It was not Federal Pacific Stab-Lok panel. It was in GE breaker panel.
  7. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    only an arc fault would have tripped
  8. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Standard breakers trip when too much current flows thru them.
    Arcing and burning can easily occur with current flow under it's rated max.
  9. Johnny C
    Johnny C Electrician
    Oct 19, 2008
    Elect Teacher, Consultant, Seminar Presenter, Elec
    Mass. & now Virginia Beach, VA
    Breaker didn't trip
    A faulty connection at the breaker terminal offers resistance to the flow of current thereby limiting the amount of current passing through the breaker. So the breaker doesn't trip due to high current. However, I have investigated instances where the heat generated by the bad connection caused the breaker to trip due to the transfer of heat from the fault into the heat sensing element in the circuit breaker.
  10. edstevn
    edstevn New Member
    Oct 27, 2008
    Thanks for your advice!
  11. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    You might want to replace the breaker.
    This is not my field, but I'd think whatever heat treatment, annealing, tempering, etc., the metal of the breaker connector received at the factory, it has certainly been erased.
Similar Threads: Breaker trip
Electrical Forum discussion & Blog 20 amp breaker trips Nov 8, 2016
Electrical Forum discussion & Blog AFCI Breakers in my Home Trip Randomly Feb 12, 2016
Electrical Forum discussion & Blog Mysterious breaker trip Sep 2, 2015
Electrical Forum discussion & Blog Dual Trip Breaker Replacement Jan 25, 2015
Electrical Forum discussion & Blog Circuit Breaker trips same time every day Aug 25, 2013
