Brass Unions
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BimmerRacer, Aug 21, 2009.
  1. BimmerRacer
    BimmerRacer Member
    Jan 8, 2009
    NOT a plumber :)
    Washington, DC
    [​IMG]
    Do I need to put anything between two halves or do I just crank it down to seal it?
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Just tighten them down the ground face of the union will make the seal.
  4. BimmerRacer
    BimmerRacer Member
    Jan 8, 2009
    NOT a plumber :)
    Washington, DC
    Thanks Ron!
  5. jadnashua
    A couple of things...make sure the pipes are aligned when you tighten things up. And, especially if you overtighten, you may find you create a ridge on the sealing surfaces, so if you need to tak it apart, it becomes more difficult to seal unless you get it aligned perfectly.
  6. hj
    unions
    I usually use pipe joint compound on the faces and the threads of the union nut to give some lubrication to the process.
  7. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    Unions
    Do to the fact that most fittings are made off planet, I also use a little pipe compound on the face, your choice. ;)
  8. BimmerRacer
    BimmerRacer Member
    Jan 8, 2009
    NOT a plumber :)
    Washington, DC
    Thanks for the tips gents
Similar Threads: Brass Unions
Plumbing Forum, Professional & DIY Advice Brass cleanout plug in older home Jan 31, 2017
Plumbing Forum, Professional & DIY Advice 3/4" threaded = brass or copper Jan 27, 2017
Plumbing Forum, Professional & DIY Advice Brass or stainless constant pressure manifold? Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Newport Brass Bridge Faucet Oct 22, 2016
Plumbing Forum, Professional & DIY Advice Brass P-trap and Galvanized Steel Stub-Out Oct 13, 2016
