Brass to Copper Connection
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Kerry, Aug 6, 2008.
  1. Kerry
    Kerry New Member
    Aug 6, 2008
    Hi, I'm a DIYer and have an old (1950's or so) bathtub faucet I need to change. The pipe leading to it is brass (looks like 1/2 inch I think). I would like to cut the brass pipe to remove the old faucet and then install a new single handle faucet. My thinking is connect a copper pipe to the brass pipe and then install the new faucet connected to the copper pipe.
    My question is: Can I simply cut the brass pipe and solder a copper pipe to it using some type of connector? If yes, what is the connector called and can I use the same flux and solder I normally use when going copper-copper?
  2. jadnashua
    That might be a threaded brass nipple. But if it is truely brass pipe, check the OD, if it is the same as copper pipe of equivalent size, you can treat it as if it was copper and solder away using a copper coupler.
  4. Kerry
    Kerry New Member
    Aug 6, 2008
    Thanks Jim! I am not home right now to check, but if the OD is not the same as the copper is there something else that will allow me to connect the two?
  5. jadnashua
    Can't think of anything. But, if that goes into a current valve, and didn't come with the valve as part of the trim/install package, it's probably standard pipe size and you could solder to it...brass solders to copper just fine.
Similar Threads: Brass Copper
Plumbing Forum, Professional & DIY Advice 3/4" threaded = brass or copper Jan 27, 2017
Plumbing Forum, Professional & DIY Advice Bathroom remodel copper and brass drains Sep 20, 2016
Plumbing Forum, Professional & DIY Advice Can Hose Bib (Brass Male) Be Connected Directly to Copper (Female) Not Fitting Smoothly Oct 14, 2014
Plumbing Forum, Professional & DIY Advice brass vs. copper PEX fittings Dec 16, 2013
Plumbing Forum, Professional & DIY Advice Brass Nipples vs. copper w/ sweated NPT fittings? Nov 12, 2013
