Brass Shower Drain
Discussion in 'Shower & Bathtub Forum & Blog' started by PEW, Dec 22, 2004.
  1. PEW
    PEW DIY Senior Member
    Brass Shower Drain rubber seal ?
    In the attached photo you will see where the screw-in ring has forced the rubber seal inwards. Is this the way it should look? There was a beveled end to the rubber seal which I placed downwards as it seemed to match the shape of the brass housing (there were no directions as to which way it should go).
    Any comments?
    Paul
  2. Terry
    Aug 17, 2004
    I believe that the screw-in ring has a taper to it that will match the taper on the rubber sleeve.
    I've been putting the taper "up".
    I run the pipe a little higher too.
Similar Threads: Brass Shower
Shower & Bathtub Forum & Blog Help removing a brass shower drain Jan 4, 2017
Shower & Bathtub Forum & Blog Any recommendation for an all-brass shower valve May 31, 2015
Shower & Bathtub Forum & Blog Westbrass Shower Drain D206B-LA Installation Instructions Jun 3, 2013
Shower & Bathtub Forum & Blog Aquabrass Thermostatic Shower Adjustment HELP Mar 16, 2013
Shower & Bathtub Forum & Blog Price Pfister brass acrylic 3 handle shower. Can it be replaced with original? Jul 31, 2010
