Brass P-Trap to Cast Iron DWV
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jlsddmar, Jun 28, 2010.
  1. jlsddmar
    jlsddmar New Member
    Nov 2, 2009
    Watertown, MA
    Hi Everyone -
    What is the correct way of joining brass to a cast iron stack? Does the connection from a sink P-trap (brass) to cast iron need to be dielectric? My condo is in a high-rise type building, so code states that a PVC trap isn't an option for me.
    Also, does cast iron dwv frequently have either 1 1/2 and 1 1/4 inlets? I had been looking at the Kohler K-8998 but need to check to see if the pipe's opening is larger than 1 1/4.
    Thanks,
    Derek
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    please post some pics it will help us see what you are trying to do.[​IMG]
  4. jlsddmar
    jlsddmar New Member
    Nov 2, 2009
    Watertown, MA
    Hi Ron -
    The wall's pretty much closed up now, so I don't think I'd be able to get anything to come out clearly. I think the installation is pretty standard though. It's a 4" CI stack that runs up through the 7 floors of an apartment-type building. The pipe has a female threaded inlet for the sink drain, which was temporarily capped with PVC when the old sink vanity came out.
    I want to install a chromed brass 1 1/4 P-trap to the cast iron, and know that copper 1/4 sweat to MIP adapters exist, but am I going to run into corrosion issues due to the different metals being in contact?
    Thanks for the help,
    Derek
  5. SewerRatz
    Nov 20, 2008
    Chicago, IL
    Thats a non-issue when it comes to drainage. Just be sure to use 17 guage p-traps.
  6. jlsddmar
    jlsddmar New Member
    Nov 2, 2009
    Watertown, MA
    Sounds good, thanks for the help.
    Do they make the adapters I'm looking for in brass, or is copper the way to go?
  7. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    I think this is what you need
    [​IMG]
    That comes with a chrome lock-nut it's 1 1/2 male by 1 1/4 compression
  8. jlsddmar
    jlsddmar New Member
    Nov 2, 2009
    Watertown, MA
    Hi -
    Yeah, I think it's something like that. That's a slip fit though, right? My P-trap is brass.
    -Derek
  9. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Use a 1 1/2" x whatever galv nipple from ci drain out to your brass p-trap
    THIS HAS BEEN PLUMBING CODE IN CITY OF L. A.
  10. jlsddmar
    jlsddmar New Member
    Nov 2, 2009
    Watertown, MA
    Hi Jerry -
    How is the brass connected to the galvanized? The P-trap isn't threaded. I was anticipating screwing the threads into the CI and then sweating the P-trap on.
    Thanks,
    Derek
Similar Threads: Brass P-Trap
Plumbing Forum, Professional & DIY Advice Brass P-trap and Galvanized Steel Stub-Out Oct 13, 2016
Plumbing Forum, Professional & DIY Advice How to connect ABS Drain to Brass P-Trap Dec 27, 2012
Plumbing Forum, Professional & DIY Advice Can I combine brass/chrome and plastic p-trap segments? Jul 19, 2010
Plumbing Forum, Professional & DIY Advice Chrome plated brass p-trap to 2" PVC Jun 3, 2007
Plumbing Forum, Professional & DIY Advice Brass cleanout plug in older home Jan 31, 2017
