tropics surfer
Hello again, just finished installing a pre-charged pressure tank and will be taking the T fitting apart after the first start-up (and it's a pain because it's in tight quarters).
The leak is coming from a 1" brass coupler (Watts, made you-know-where) that appears to thread correctly until the last two or three turns, where it takes on a visible angle. This is the second one of these couplers I tried; the first went back to the orange box store and was exchanged for another, and although it looked like it was threaded straight and true (in the store-even took a threaded nipple with me) it did not show it's defect until threaded tightly.
This was installed with a teflon based thread sealer paste, which hasn't worked.
What are my options?
When I take it apart will the threaded nipple be damaged also?
I'll need a new brass coupler, correct? (where to find a better quality coupler?)
Would a threadlocker work with a new one? What brand?
Problem #2
trying to put a 3/4" braided beverage type hose onto a threaded brass pipe nipple isn't holding water. Have placed rescue tape over threads and tightened the hose clamp down tight, still leaks.
Any ideas?
Thanks in advance....
Problem #2
Any ideas?
