Brass air fittings
fittings
The link is useless, but there are no "air fittings". There are fittings that can be used for air, but they can also be used for anything else you want them for.
Gardner
DIY Senior Member
Ontario
There are fittings that are designed for a certain application. Maybe there are no "DWV" fittings either, by this definition, since I can make a hampster habitat out of ABS parts.
Electrical conduit fittings, DWV and built-in vacuum fittings, however similar, are not interchangeable. They can reasonably be referred to as conduit, DWV and vacuum fittings.
When's the last time you used one of these under a sink to hook up an icemaker? Maybe never -- because this is an air fitting.
fittings
Okay, so there are FEW air fittings, but this posting implied that all the fittiings at that site, whatever they are, were air fittings, but they could also be used for other purposes.
Gardner
DIY Senior Member
Ontario
It was spam to begin with, so we've both already wasted more time than it was ever worth.
