Brand New Washing Machine Hose Squirts Water Everywhere, What Am I Doing Wrong???????
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Military Jeeper, Mar 17, 2009.
  1. Military Jeeper
    Military Jeeper New Member
    Mar 17, 2009
    Everyone,
    I'm at a complete loss!!! I just relocated my washing machine from the bathroom to the kitchen (I installed a stand-up shower in the bathroom and built a cabinet in the kitchen for the washer/dryer).
    I've bought two Floodsafe Stainless Steel hoses, and a set of rubber hoses (all with the L bracket connection which connects to the washing machine side (total of 3 hose sets). All of them are gushing water from the L-Bracket connection which connects to the washing machine side.
    The water supply side doesn't leak at all, but the washing machine side, with the L bracket literally POURS water out of the center of the connection. The ONLY thing I can think of is that the original hose (which has a plastic connection L bracket), which also connects to a plastic fitting which is permanently fixed to the washing machine is the problem since "ALL" of the hoses I've bought are metal threads on both ends, vice the original which is metal threads on the water side of the hose, and plastic threads on the washing machine side of the hose????
    Is this the problem? Can I not connect a metal threaded hose to a plastic threaded connector? As I mentioned before, this is the 3rd hose that I've installed and none of them work except the original hose that came with the washing machine (metal on one end, plastic on other end). When I reinstall the original hose, no problems at all, when I install a new hose, it pours water from the center of the L bracket metal connection!!!!!!
    If this is the case, where in the HELL can I find a 6 foot hose that is plastic on one end, and metal on the other so I can install my washing machine safely without worrying about flooding the apartment below mine.
    I'm at a loss guys, please help!!!
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Awe man!
    You cross-threaded it and broke it!
    Not good! Take pictures!
  4. Military Jeeper
    Mar 17, 2009
    The first picture is the original connection. Note that one side if plastic (washing machine side) and the other side is metal (water supply side:
    [​IMG]
    The second picture is the 3rd set of hoses I bought from Home Depot/Lowe's. All the aftermarket hoses I've bought have been metal threaded both sides:
    [​IMG]
    The third picture is of the L bracket shaped hose connection. Notice the center of the connection, where the L-bracket connects into the threaded portion. The water is gushing from the center where the two pieces connect (Yes, the washers are installed):
    [​IMG]
  5. Military Jeeper
    Mar 17, 2009
    It's not cross threaded, it's not leaking from the threads. It's leaking from the connector where the L-bracket elbows into the metal threaded circular piece.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Do you have rubber washers inside those connectors?
  7. Military Jeeper
    Mar 17, 2009
    Yes, the washers are inside.
  8. jimbo
    jimbo Plumber
    San Diego, CA
    What brand of machine? I would not allow a hose with a plastic fitting on it in the SAME STATE, and certainly not inside my house. You are asking for a disaster on that.
    I can only think that some off brand or import machine has non-standard threads on the inlet?? And maybe that is why only their hose works??
  9. Cass
    Cass Plumber
    Nov 12, 2005
    What are you using to tighten them???
  10. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Although it might be kinda hard, can you connect the 90 degree connection to the hot or cold supply and have the straight connection going to the washer¿ I realize why you are using the right angle hose, to gain extraspace (or are you¿ if not try a regular washer hose) Does it still leak at the 90 with them reversed¿
  11. hj
    hoses
    Why aren't you using hoses with metal angle ends on them instead of the plastic ones. If it is leaking ANYWHERE except where it connects to the washing machine the hose is either not tight or it is defective.
  12. Military Jeeper
    Mar 17, 2009
    Everyone,
    The original hoses that were installed were made by Whirlpool (machine and hoses came together when I bought the machine). The original hoses that came with it, which have a plastic L-Bracket (90 degree bracket) don't leak at ALL.
    The aftermarker hoses, all which are metal and have a L-Bracket (90 degree bracket) leak at the where the 90 degree bend is on the hose side that attaches to the washing machine.
    Problem...............factory plastic one's don't leak, aftermarket metal ones do.
  13. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Sometimes the trouble is the socket on the new hoses are to deep so no matter how tight you tighten them you will not compress the washer. You can try doubling up a washer in the metal ends or find a thicker hose washer.
  14. Military Jeeper
    Mar 17, 2009
    That's what I think the problem is personally, but I don't feel safe with doubling up washers as the resolve to the situation when I live in a condo and people live beneath me. Any other thoughts?
  15. jadnashua
    See if you can find some that are thicker. Also, you could measure the depth of the OEM ones verses the new ones. It should be obvious if when screwing them on if you are bottoming out on the shell or compressing the washer.
Similar Threads: Brand Washing
Plumbing Forum, Professional & DIY Advice Help identifying shower faucet brand Mar 18, 2017
Plumbing Forum, Professional & DIY Advice Faucet Brand Identification Mar 8, 2017
Plumbing Forum, Professional & DIY Advice Faucet brand Feb 27, 2017
Plumbing Forum, Professional & DIY Advice Please help identify this faucet brand TY Feb 21, 2017
Plumbing Forum, Professional & DIY Advice Plumbers: Which kitchen faucet brands are tops in quality/reliability? Feb 9, 2017
