Brand new pump, brand new tank
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Molly, Dec 1, 2005.
  1. Molly
    Molly New Member
    Nov 1, 2005
    We just replaced our jet pump and our pressure tank. We set the tank pressure at 18psi, 2 less than pump cut in pressure of 20psi. After the pump runs the tank has 30 to 35 psi. This causes the pump to keep running. Why does the pressure build up by itself?
  2. jadnashua
    It is probably a little low, not high. Most systems are set to values about 20#'s apart. It turns on at 20 in your case, and shuts off at 40. Putting pressure in the bladder tank keeps the bladder from expanding too much and failing early. The pump provides the energy to compress the air in the tank. The spring in the bladder keeps pressure while the pump rests prior to needing to turn back on at 20 pounds, pushing that stored water out of the tank.
  4. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    Owner - R.L. Peeks Pump Sales
    So. Cal
    Set the tank at an 18 psi precharge. (Pump off, tank empty).
    After the pump has ran, turn off the power and completely drain the tank. If the pressure still reads 18 psi, you're ok. If it reads higher, you have a problem with the tank.
    With the system pressured up, you will have the same reading at the pressure tank as the reading on the system gauge,
    Ron
  5. Molly
    Molly New Member
    Nov 1, 2005
    We drained the tank, pumped 18# into it, turned on the pump,it shut off at 30#, we drained again, it now reads 0#. We turned the pump on with 0# in the tank, and it is now up to 35# and shutting off by itself. This seems great, but later on today after washing clothes and a shower or 2 along with some dishes being done (not at the same time) the pump will not shut off on its own and we have to shut it off at the breaker. We turn it off and on real quick and it just goes off. I do have a theory, because everything is new, Can it be, our well is 35ft deep with about 6ft of water when filled. We have a deepwell jet pump. Maybe we are asking too much of the whole system. IN other words, are we asking this system to supply too much water in too short of a time period?
  6. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    So. Cal
    Are you reading 0# at the air valve on the tank, or on the system pressure gauge?
    Ron
  7. Molly
    Molly New Member
    Nov 1, 2005
    We were reading 0# at both the gauge and the tank valve. When we turned the pump back on it pressured itlself back up to 37# and shut off.
  8. speedbump
    speedbump Previous member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Can you tell us more about the pump and tank you bought?
    bob...
  9. Molly
    Molly New Member
    Nov 1, 2005
    The pump is a Water Ace made by Meyers. Is a deep well, 1/2 HP, jet pump. The tank is a 20 gal. diaphram type tank.
  10. speedbump
    Jul 15, 2005
    Riverview, Fl.
    You should certainly be able to get more than 38 lbs. if all is working like it should. I'm curious as to what pump you took off and it's name and horsepower.
    You really need to shut the pump off and put the 18 lbs. back in the tank and leave it there. This is done like Ron stated above, with the pump off and the gauge at zero.
    bob...
  11. Cass
    Cass Plumber
    Nov 12, 2005
    Sounds like the well tank (bladder) is not holding air, I'm guessing the schrader valve is not tight or needs replacement.
  12. speedbump
    Jul 15, 2005
    Riverview, Fl.
    What brand is the tank?
    bob...
Similar Threads: Brand pump
Pumps and Tanks Well Forum & Blog New well owner! Pump sizing and brand help... Oct 7, 2015
Pumps and Tanks Well Forum & Blog What pump brand is prefered for a 350ft well in central FL? Jul 7, 2015
Pumps and Tanks Well Forum & Blog Suggestions for brands of well pump? Nov 3, 2014
Pumps and Tanks Well Forum & Blog What is the Best Brand submersible Well Pump (Made in USA)? Apr 4, 2014
Pumps and Tanks Well Forum & Blog Shallow Well Pump Brand And contruction questions Mar 3, 2014
