Brand new Moen Posi-Temp Tub & Shower Valve, Model 2300:
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by oldberkeley, Apr 4, 2010.
  1. oldberkeley
    oldberkeley Member
    Nov 20, 2009
    Columbus, OH
    Turn on, works fine.
    Turn off, constant drip from tub spout.
    Help appreciated, thanks in advance.
  2. Terry
    Aug 17, 2004
    A tub faucet will drip for 35 minutes after use.
    It take that long for all of the water to completely drain down.
    If it doesn't shut off after that amount of time, or it's more like a constant running, then you may need to fix or replace the cartridge.
  4. hj
    35 minutes may be a bit much, but if it is just residual water in the piping, then it WILL stop eventually. If it does not then the cartridge is damaged and you need to replace it.
  5. Terry
    Aug 17, 2004
    I have timed them several times.
    I had one anal customer, that once her 40 yo faucet had been replaced, then expected instant water shutoff on the new fixture.
    I started keeping track of time, how long tubs would take to finally quit dripping after shutoff.
    Average time, if your anal customer is hanging out in the bathroom watching the tub spout, 35 minutes.
    What the heck is wrong with watching "The Price is Right"?
    Why do they grab a chair and watch the tub spout?
    Forget about it.
    The water is off.
    It takes that long to become bone dry inside all those pipes in the wall.
    That's why, when I shut off water for a plumbing repair, I open up every faucet in the home, starting at the top.
    If they have four bathrooms, I go into four bathrooms and start opening faucets.
    The quicker all that water can finish sliding out of the pipes, the sooner I can start soldering the new joint.
    You can't solder if water continues to drip for hours.
    And you other plumbers, don't you love it when the HO tells you over the phone that you can cut, install a fitting and solder in 15 minutes.
    It takes way longer then that for the water to quit leaking toward the new joint.
    With these guys, I tell them to keep looking.
    I'm pretty fast, but you can't beat nature.
  6. oldberkeley
    oldberkeley Member
    Nov 20, 2009
    Columbus, OH
    Terry & HJ- As usual, thanks for your prompt and informative replies. After taking exhaustive pains to get the thing in right, I just wanted to make sure that I didn't have a damaged valve. My wife is the one that says to me,"The spout is dripping!" I showed her your posts, it did stop after awhile, all is well. :)
Similar Threads: Brand Moen
Plumbing Forum, Professional & DIY Advice Please help identify this faucet brand TY Tuesday at 3:53 PM
Plumbing Forum, Professional & DIY Advice Plumbers: Which kitchen faucet brands are tops in quality/reliability? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Help identifying faucet brand! Dec 17, 2016
Plumbing Forum, Professional & DIY Advice Please help me identify the brand of this lavatory faucet Oct 18, 2016
Plumbing Forum, Professional & DIY Advice No brand toilet trip lever Oct 2, 2016
