Bradford white question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Stbentoak, Sep 26, 2007.
  1. Stbentoak
    Stbentoak New Member
    May 1, 2007
    I have a 40 gal nat gas BW heater that is appx 2 yrs old. Recently it seems like the thermostat on the unit only works appx 50 % of the time. It is set on the median suggested mark and once or twice a week it will run out of hot water and the unit will not call for heat to keep it warm. If i turn it up towards really hot it will fire and heat the tank and shut off like normal and then maybe work a day or so normally.
    It there something that needs to be cleaned / adjusted or replaced that makes sense? Some kind of sensor?
    It is in a relatively clean environment in a basement,(Some minor pet hair etc) but nothing crazy. I would appreciate any help/ suggestions.
    Thanks
    Stbentoak:)
  2. Cookie
    Cookie .
    Oct 7, 2005
    As long as this is not a power vent heater it is likely that the thermostat is going bad. You will probably have to replace the thermostat/gas valve. That should take care of the problem.
Similar Threads: Bradford white
Plumbing Forum, Professional & DIY Advice Replace HW heater anode rod ... Bradford White combination outlet/rod Jan 19, 2016
Plumbing Forum, Professional & DIY Advice Bradford White Hot Water Heater Pilot Flame Jan 15, 2015
Plumbing Forum, Professional & DIY Advice Bradford White MI403S6FBN Nov 18, 2012
Plumbing Forum, Professional & DIY Advice Bradford White or Rheem Feb 7, 2012
Plumbing Forum, Professional & DIY Advice Bradford White Water Heater ??? Jan 5, 2009
