Bradford white lowboy
Discussion in 'Water Heater Forum, Tanks' started by Cybermonkey, Apr 6, 2009.
  1. Cybermonkey
    Cybermonkey New Member
    Mar 16, 2008
    Vermont
    Hey guys,
    I am in the process of getting ready to install a hot water heater. My idea is to install the HWH in a closet underneth a stairwell. The problem is my max height is 48". So, I am considering a Bradford White Lowboy 47 gal version. I have a wife, two kids and two bathrooms. I think I will get just enough hot water but am not quite sure. What do you guys opinion????
    BTW, I have no Whirlpool tube or dishwasher.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    it will work ok
    you are talking about a gas low boy, correct???
    that will be more than big enough...
    it will work fine as long as it is permitted to install one
    under a stair well in your area..
    and as long as it dont get starved for air.
    I suggest you put it in a pan for the day will come
    when it will go bad .
  5. hj
    heater
    It had better be an electric heater if he is putting it under a stairway. And the 47 gallon lowboy is equivalent to a 50 gallon regular so you should have no problem with it.
  6. Cybermonkey
    Mar 16, 2008
    Vermont
    It will be an eletric HWH. I will definitly take your advice and put a pan under it! Do they make a drain for the floor that acts like a check valve? The HWH will sit on my first floor above my crawlspace. If I had a drain to the crawlspace below I would be golden. Accept I am probobibly not seeing a code issue or two.
    Thanks for your help.
Similar Threads: Bradford white
Water Heater Forum, Tanks Bradford White - Is a Gas Leak from Control Valve Normal? Sep 9, 2016
Water Heater Forum, Tanks Bradford White Combi Core 1 vs Combi Core 2 Jun 1, 2016
Water Heater Forum, Tanks Bradford White pilot issues Apr 1, 2016
Water Heater Forum, Tanks Bradford White low nox repeated flame rollout. Jun 28, 2015
Water Heater Forum, Tanks Water heater control valve? Bradford White MI40T6FBN Jun 26, 2015
