Johnnyman7
Hello all,
I had a 50 gal Bradford White Natural Gas Water Heater installed about a month ago. Everything works great, except that I get a faint smell of natural gas that seems to be originating from the top right of the Control Valve/Box. You have to be within 4 inches of the Control Valve to smell it....any further away and the smell disappears. I believe the Control Valve is manufactured by Honeywell.
I was worried enough to call the Gas Company a few weeks back. They detected a very small amount of natural gas being released (something about 20???), but not enough to red-tag the appliance.
I've always been taught that ALL natural gas leaks are bad, so I then called Bradford White Tech Support. They immediately knew what I was talking about and said it was normal to smell natural gas if you put your nose up to the Control Valve. They stated that there's a relief valve in the Control Box that continuously releases a small amount of gas into the air to compensate for the difference in the natural gas pressure coming from the supply line versus what the appliance actually uses. I contested this ("aren't all natural gas leaks bad?"), but they assured me this was normal.
I'm just a Joe Schmoe homeowner, so I'm hoping for some advice:
1) Is it normal for the Control Valve to release a small amount of natural gas, or is Bradford White giving me a load of crap?
2) Is this dangerous in any way?
3) Is there anything I can do to minimize the gas being released? I was thinking of slightly closing the valve on the gas supply line to (theoretically) reduce the pressure going to the water heater, but I also don't want to mess anything up.
Thank you in advance!
