Box for Lantern style lights?
Discussion in 'Electrical Forum discussion & Blog' started by sandyman720, Sep 26, 2007.
  1. sandyman720
    sandyman720 New Member
    Mar 5, 2007
    What is the best type of box to use for installing outdoor lantern style lights? How do you secure this box?
    My siding block does not have an integrated box in it.
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Go to your local electrical supply house and tell them what you have and what you need. There are several different ways to handle your problem and they will be glad to help you choose which method will suit your needs best.
    Be sure to take your check book along with you.
  4. sandyman720
    Mar 5, 2007
    Well what do you all normally do? Do you normally install a plastic box in the wall? How do you brace?
  5. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    As I have already said, I go to the electrical supply house and get the box that I need for the job I am doing.
    They make a box that is the trim itself. It can either be used on new or old work.
    What you can do at the supply house that you can't do here is get what you need for the job you are doing.
    [​IMG]
  6. sandyman720
    Mar 5, 2007
    I can get a jumbo mounting block that is the same color as my siding (Green) but it does not come with an integrated box like the one you show. But I just way to know what kind of box to put behind the siding. By code there has to be a box.
  7. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    One more time. Go to the electrical supply house with your problem and they can help.
    What we don't know is how the installation is being made nor what it is being made on.
    Scenario one
    There is a wood finish that has been covered by siding
    Two
    There is brick behind the siding
    Three
    There is nothing behind the siding but there is no stud where the fixture is going
    Four
    There is nothing behind the siding and there is a stud where the light is going
    Five
    Any of the above four scenarios above but the siding is a board and batten
    And this can go on all day long.
    To get a box as pictured above all these problems are solved and the installation is easy.
    To try and install a box behind the junk the siding people furnishes and the installation can end up costing a lot more than the price of a vinyl box and the labor to install it.
    One last time go to the electrical supply house and have them help you with this problem.
  8. frenchelectrican
    frenchelectrican Electrician
    Jun 16, 2007
    Master Electrician
    NE Wis / Paris France { In France now }
    The other thing with the siding block what Jwelectric provide the photo to you that the siding junction box that itself it is paintable to match to the colour to your exsting siding colour.
    Merci, Marc
    a side note some junction box just cant take big lumniaire at all some are restricted to 6 or 10 lbs but if you mounted properly it will hold more weight just follow the instructions ditto with the lumniaire's instruction as well
  9. electrical
    electrical New Member
    Apr 17, 2008
    Wholesale Electrical Supply
    Electrical Industries is a wholesale electrical supply company with a comprehensive list of electrical supplies for every need including, residential, and commercial. Browse our online electrical supply store.
    http://www.electricalindustries.com
Similar Threads: Lantern style
Electrical Forum discussion & Blog Lantern Style lights outside. Work box? Sep 13, 2007
Electrical Forum discussion & Blog Old style 220 (3 wire) to new style (4 wire) connection Sep 3, 2011
