bottle trap
Discussion in 'Canadian Plumbing Code Questions' started by gardner, Nov 27, 2008.
  1. gardner
    gardner DIY Senior Member
    Apr 2, 2007
    Ontario
    So my new sink is installed and plumbed and seems to be okay. The new sink's tailpiece is quite close to the wall and consequently there is very little -- actually not really enough -- room for the trap. For now I have the trap running outward and looped back so it can be used, but it looks weird.
    I have two possibilities to get the installation fixed up -- I can move the trap adapter over to the side, or I can use a bottle trap.
    I'm not sure how guys who deal with them feel about bottle traps. The ones I can find seem to be pretty pricey. I want to spend not more that $50 on a reasonably decent one -- not a designer one, just something durable.
    Any opinions whether bottle traps ought to be avoided for any reason?
    Any suggestions of a cheap serviceable model to look at?
  2. jadnashua
    I'd just leave what you have there...a bottle trap isn't self-cleaning, if I understand how they work. A standard p-trap essentially is as long as the flow is decent.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Depending on how it is constructed, bottle traps are generally not code approved. 1004.0 of the CA plumbing code says "...bottle traps shall be installed ONLY for special conditions" . It would be up to your inspector as to whether you qualify as a "special condition?"
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Bottle traps are not allowed by many codes.
    They rely on an internal partition to provide the trap seal.
    There is no method of inspection that will reveal whether or not this partition has corroded away and is allowing dangerous sewer gases to enter your home.
    The method you describe of going past and swiveling the trap around to fit is acceptable. You could move the drain in the wall over or you may even add an elbow to it to allow a better fit.
  6. Terry
    Aug 17, 2004
    Maybe this is a dumb question, but how much of the trap arm toward the wall was cut off, and you still didn't have enough room to connect it?
    Your sink drain must be right up against the wall if you can't cut the trap enough to install it.
  7. gardner
    Apr 2, 2007
    Ontario
    Hi Terry,
    The tailpiece comes out about 5 inches from the wall on my Crane sink. The sleeker Toto wall mount that I had my eye on has the drain barely over 3 inches from the wall.
    My new trap adapter (remember the 1-1/4 banded coupling thread?) comes proud of the wall by over 3/4. The initial bend in the trap arm needs about 2 inches, the trap itself is over 3. There is just not enough space for the trap between the tailpiece and the trap adapter.
    I didn't cut the trap arm at all, thankfully, as the trap itself doesn't even fit. The trap arm is just long enough to reach the trap after swiveling it the other way around.
    I just rummaged out the Ontario code and they won't allow bottle traps here. It seems like I couldn't get one if I wanted it. Maybe there is room for someone to invent a bottle-like trap (a very narrow U-bend, with a removable shroud, say) that would meet the code requirements but fit the compact installs.
    The backward loop looks dumb, but will have to do until I get my bum in gear to swap out the sink and re-arrange everything. I needed to get this bathroom in service so I will leave that until I come up with something else.
  8. gardner
    Apr 2, 2007
    Ontario
    This is the Toto Sink I had in mind:
    http://www.totousa.com/admin/upload/pdfspc/s-lt650g-1107.pdf
    and I can't see how you could connect it to the rough-ins they show without using a bottle trap.
    To put this in my place, I will have to mount the sink over from the drain to allow the trap to run parallel to the wall and move one of the supplies over so the supply stub doesn't interfere with the drain.
    It looks pretty though, and fits in the compact space I have to work with.
  9. jadnashua
    In a week or so, you won't notice it, and neither will your guests...sometimes you've got to do what you've got to do. It will work fine.
Similar Threads: bottle trap
Canadian Plumbing Code Questions p-trap vs bottle trap May 11, 2014
Canadian Plumbing Code Questions Bottle trap question Jul 9, 2010
Canadian Plumbing Code Questions Trap location for kitchen sink Sep 13, 2015
Canadian Plumbing Code Questions Traps and Venting in New Brunswick - old buildings Dec 20, 2014
Canadian Plumbing Code Questions 'Nuther S-Trap Dilemma Jun 9, 2014
