Bonding Water Heater
Discussion in 'Electrical Forum discussion & Blog' started by chuck b, Jun 28, 2011.
  1. chuck b
    chuck b sea-bee
    Jan 19, 2011
    levering, michigan
    Is it wise to provide a bond between the hot and cold water pipes of a water heater?
    The electrical panel is for a 200-amp service, so should a #4 gauge wire be the right size then? Is it NOW correct to also bond the natural gas pipe along with the hot and cold pipes? Does doing so create any kind of hazard?
    Thanks, Chuck
  2. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    If your house is plumbed with copper or galvanized pipe you should have a bond to the cold water pipe already. A shower valve completes the bond to the hot water side.
    The gas line will be sufficiently bonded by the gas appliance's electrical connection. This assumes you have an equipment ground on the circuit that provides power to the appliance.
    When was this house built? Is the water line to house metal? What kind of gas piping do you have?
  4. chuck b
    chuck b sea-bee
    Jan 19, 2011
    levering, michigan
    Reply
    Thanks for the information.
    House is plumbed with copper with a jumper on each side of the water meter. The natural gas line in question by the water heater is of course not electric, but the nearby natural gas furnace is which the gas line also supplies. Not sure what you mean by a shower valve completing the bond.
    Your comments?
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    The only requirement for bonding a metal water pipe is found in 250.104 and this section requires the bonding point to be accessible.
    There is no requirement to bond the hot to the cold as they both are from the same potable water system. If you are worried about the bonding taking place the valve that is used to turn the hot and cold water on at the shower does this bonding as well as other types of plumbing mixing valves and supports.
    The gas pipe will need to follow the installation instructions that come with any flexible connections to the gas equipment. All 250.104 calls for is the equipment grounding conductor that is installed with the branch circuit conductors supplying a piece of gas equipment such as the heat.
  6. ActionDave
    Feb 4, 2009
    Electrician
    Colorado
    He said it better.
  7. hj
    Placing a bond between the hot and cold lines at the heater is ALWAYS a good idea. Many heaters start leaking because of "stray" currents passing from the hot side to the cold by going THROUGH the water heater, and since this is a high resistance path, it deteriorates the water heater. I once had a heater that lasted 4 months and when it failed it was like someone used a can opener on the top of the heater DIRECTLY from the hot outlet to the cold inlet. There is usually no sign of electrical activity to be detected, but after I installed a jumper between the two pipes, they never had any more troubles.
Similar Threads: Bonding Water
Electrical Forum discussion & Blog Gas water heater bonding Jan 8, 2014
Electrical Forum discussion & Blog Bonding a new water supply line Feb 19, 2012
Electrical Forum discussion & Blog Grounding Whirlpool Tub Motor and Heater - Bonding Panel to Electric Water Heater Feb 5, 2012
Electrical Forum discussion & Blog Bonding ground rod to water pipe to nuetral bus Jan 29, 2008
Electrical Forum discussion & Blog Grounding, bonding, old swimming pool Feb 23, 2014
