Mark Olenick
I've got a good memory. It's just short ;-/
Hello all,
Just purchased a residence that has a new(er) EATON 200 Amp load center with main breaker. When I inspected the panel I noticed the neutrals and grounds were bonded on the opposite sides (Grounds connected to bar with neutral lug and neutrals connected to bar with ground wire lug). As part of the panel there is a common bar going between the neutrals and ground bars so they are the same potential I would assume.
Any issues? Should I be rebonding to proper side.
Thanks
Thanks
