boiler vent size problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lurch, Jun 8, 2009.
  1. lurch
    lurch New Member
    Jun 8, 2009
    NJ
    I have a dispute between my plumber and the inspector and I'm hoping someone here can help out.
    I have a WM CGI-5 propane direct vent boiler that was planned to be a direct vent however my plumber determined that for whatever reason he would connect it to the chimney as the old oil furnace was.
    The vent is 3" stainless that travels 2 ft vertically and then through a 90 deg elbow into the old masonry pipe the boiler used which is a 6" opening that he has sealed with some kind of mortar.
    The plumbing inspector is concerned with this and in the Weil Mclain installation manual - its clearly states for chimney venting a 5" pipe is required. I assume this is a negative pressure scenario.
    However the plumber claims that as this is a positive pressure vent the 3" vent is correct - the WM manual just doesn't cover direct vent into a chimney. Who is correct?? Help please.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    You go by what the manufacturer says in all cases. Weil McLain wants 5" here and that's what it needs to be.
  4. lurch
    lurch New Member
    Jun 8, 2009
    NJ
    Thanks nhmaster - my current vent is stainless steel - can I use galvanised to replace it - the WM manual does not specify this.
    Also here is a pic of the vent and chimney connection.
    Any advice/comments welcome.
  5. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Can you post more pics of the mechanical room. I am just grasping hydronics and I have this thing for mechanical rooms.
  6. lurch
    lurch New Member
    Jun 8, 2009
    NJ
    sure - its not too pretty...
  7. kingsotall
    Aug 17, 2008
    So the boiler is not supplying heat for DHW¿ I see one pump but where is the secondary/system pump¿ What types of controls are you using¿
  8. lurch
    lurch New Member
    Jun 8, 2009
    NJ
    there is a propane HWH to the right - the boiler feeds the 2 baseboard zones with zone valves. This is controlled by the thermostat. Thermostat opens - this opens the zone valve and turns on the red circulator. I also have a zone with Onix tube radiant flooring. I'll probably add a circulator to this zone.
  9. hj
    vent
    Check with W/M to see if the 5" is a minimum size, not an absolute.
  10. lurch
    lurch New Member
    Jun 8, 2009
    NJ
    thanks HJ - do you know if I can use Galv vent pipe for a boiler?
  11. seaofnames
    seaofnames DIY Senior Member
    Jan 25, 2009
    Boilermaker
    Mission, BC
    Of course you can use galvinized pipe for venting a boiler...it will not last as long as stainless, but its a good investment none the less.
    They also make 4" Plastic pipe for venting which I've seen used on some of the IBC boilers we install. Its just rated for a high temperature.
  12. jadnashua
    When it comes to installation of something like a boiler, you MUST adhere to the manufacturer's instructions. If they say SS, then you must use SS. If they give you options, as long as you use one of them, you're okay. You CANNOT make assumptions here. If it isn't stated in their manual, and you have a question, the best answer is to call their tech support number. The condensate of some boilers can be so acidic that it will quickly leach the cement out of mortar joints, degrade a chimney, and eat right through anything but stainless steel, and even then there have been problems with the use of the wrong alloy.
  13. lurch
    lurch New Member
    Jun 8, 2009
    NJ
    Just spoke to WM tech services - in this circumstance - venting into the chimney - I can use a single wall Galv pipe - 5" .
    OK - problem resolved
    Thanks for all the advice guys
Similar Threads: boiler vent
Plumbing Forum, Professional & DIY Advice Primary Loop on a condensing-style direct vent boiler Jun 19, 2013
Plumbing Forum, Professional & DIY Advice Tie sink vent & boiler vent together? Jan 4, 2010
Plumbing Forum, Professional & DIY Advice Improperly installed flue vent cap cause of boiler fire? Aug 21, 2009
Plumbing Forum, Professional & DIY Advice Side venting a water heater and boiler Jan 13, 2005
Plumbing Forum, Professional & DIY Advice Boiler Combustion Air venting question Nov 17, 2004
