Voyager1947
I have a fairly new Burnham Boiler which recently started having an intermittent problem. What it does when it has the problem is...it has two zones, taco zone valves, and is wired according to the manual, the internet, youtube, etc, and the fact that this problem is intermittent makes me think the wiring is correct. When either thermostat calls for heat, the circulator turns on, the burner turns on. If the water temp gets above the set limit, the burner turns off, circulator continues, then the burner turns back on after the water temp drops. At times, when the thermostat is satisfied and no longer calls for heat, the burner turns off, but the circulator keeps running. With it running, and the zones closed, the water temp will take forever to drop, which I would expect. In reading everything I can about troubleshooting this thing, one thing that don't make sense to me after doing voltage checks is that if I remove the wires from both T terminals and put my meter across them, it reads 41.5 vac and if I reverse the leads it reads 15.7 vac. I've seen this control thing where the T terminals are called an aquastat, but what is printed on it is Intelligent Oil Boiler Control and has a number of Honeywell L7248L, it just don't seem like it should have voltage on it as there is an external transformer supplying the 24vac to the thermostats. Any ideas would be appreciated.
