Boiler Question? ?
Discussion in 'HVAC Heating & Cooling' started by JoeD, Feb 13, 2007.
  1. JoeD
    JoeD New Member
    Dec 14, 2005
    Hi - I have an 8yr old OIL-Fired Weil-McLain Boiler with a Becket
    Question: The past few months I can see Sooth(Black) look
    around my Chimney Cap and some on the side of my house.
    Is the Burner set to RICH?
    Does it Need More Air?
    What can I do?
  2. Lancaster
    Lancaster New Member
    Nov 7, 2005
    There's not a whole lot you can do.But an oil burner technician with the proper test instruments can make the necessary checks and adjustments in a surprisingly short time frame.I used to fool around with my oil burner and never did get it working correctly until a tech with the appropriate instruments checked it out and had it working like new in about 15 minutes.
  4. jadnashua
    Usually, someone that knows answers. Hasn't happened yet! Soot, to me anyways, seems to indicate the burner is not adjusted properly. Adjusting it is somewhat art and science. To do it properly, you need CO meter, and probably some other tools. You can probably get it close by eye (assuming you know what to look for and know what to adjust).
    A good cleaning of the orafice and burner might be all it needs to restore it to proper operating condition. This procedure is often covered in the manual. If you don't have that, you might find it on-line. Otherwise, it may be best to call a pro since an inefficient burner can be both a financial and health problem.
Similar Threads: Boiler Question
HVAC Heating & Cooling Boiler size question Dec 21, 2015
HVAC Heating & Cooling Question about Burnham Alpine 150 BTU Boiler question Nov 19, 2013
HVAC Heating & Cooling baseboard heat/boiler question Feb 6, 2009
HVAC Heating & Cooling Boiler Heating Question Nov 22, 2008
HVAC Heating & Cooling Boiler/Water heater question Nov 7, 2007
