Boiler pressure
Discussion in 'Boiler Forum' started by my88r, Apr 17, 2011.
  1. my88r
    my88r New Member
    Apr 17, 2011
    Horseheads, NY
    I have a boiler in my basement. That does the apartment upstairs it goes up the wall to there ceiling. The building is 2 store and the boiler goes up to the apartment. There's a pressure difference is goes to about 30 psi. When running the thermostat at 70 degrees. Is that cause it goes upstair and goes along distance. Will this hurt anything.??
  2. jadnashua
    Depending on the boiler, 30# might be normal, but that seems high for just two stories. To keep the pressure semi-constant, the expansion tank needs to be working. This could be an older style air over water tank, or a newer bladder tank. You may need to replace the bladder tank or purge the old tank to get it to regulate properly. Also, if you have an autofill valve, it could be worn out and letting new water into the system. And, if you have a tankless coil, it could have a leak in it, raising the pressure.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    30 lbs is where the relief valve does it's thing so no, the system pressure should not be any higher than 15 lbs. Drain or replace the expansion tank. If the pressure still climbs test the auto fill or for a leak in the hot water coil if you have one.
  5. jadnashua
    Most residential boilers use 30# relief valves, but there could be a higher pressure one there in an unusual circumstance. Normal operating pressure is typically in the 15# range. A failed expansion tank will cause the pressure to rise, often enough to cause the relief valve to open.
Similar Threads: Boiler pressure
Boiler Forum Oil Fired Boiler Exceeds 30 PSI Pressure Mar 4, 2016
Boiler Forum Boiler pressure range. Air intrusion. Feb 29, 2016
Boiler Forum Incorrect boiler pressure relief valve installed Feb 19, 2016
Boiler Forum Alpine boiler losing pressure when isloated Oct 8, 2015
Boiler Forum Boiler pressure problem Apr 23, 2015
