Boiler not operating within Hi Lo limits
Discussion in 'Boiler Forum' started by ut7351a, Dec 7, 2010.
  1. ut7351a
    ut7351a New Member
    Dec 7, 2010
    PA
    I have a Teledyne Laars Max D100 Boiler w/ indirect hot water. It is a cold start boller. It has separate Hi Lo limit controls. Hi limit set at 200F, Lo limit set at 180F. Problem: When thermostat calls or heat, boiler heats up to about 165F & burner cuts out. As water circulates boiler temp starts to drop. When boiler temp drops to about 155F, burner kicks back in & heats up to about 165F again & continues back & forth until thermostat is statisfied. Why isn't boiler operating between the Hi Lo control settings?
  2. jadnashua
    Does it have an outdoor reset controller? If so, it adjusts to the load and outside temperature and overrides the manual settings.
  4. ut7351a
    ut7351a New Member
    Dec 7, 2010
    PA
    No Outdoor controller.
  5. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    This boiler probably has a safety high-limit aquastat in addition to the operational high/low settings. If the safety is set (or has failed) to 165F (lower than the operational high limit) it would exhibit this sort of behavior- kick off at 165F, back on again at 155F, repeat...
    Is this the boiler in question?
    If it's this series or similar and you incorrectly assumed the safety aquastat to be the low-limit, that could be the whole issue. (although 165F is way lower than the 180F you set it to.)
    What model aquastat(s) does this beast have?
Similar Threads: Boiler operating
Boiler Forum Weil McClain cga6pidn boiler Friday at 1:49 PM
Boiler Forum An American Standard Gas boiler Mar 13, 2017
Boiler Forum Boiler slowly fills Mar 7, 2017
Boiler Forum Should I replace ~70-year-old boiler? Mar 5, 2017
Boiler Forum Boiler Water Temperature Calculation Mar 2, 2017
