Boiler Front Gasket Leak
Discussion in 'HVAC Heating & Cooling' started by jmacl, Jan 27, 2013.
  1. jmacl
    jmacl New Member
    Jan 27, 2013
    RI
    Hi All,
    I just had a quick question about the size of the job to replace the front gasket on my boiler.
    The sweating shouldn't be an issue for me, but I am a little worried about draining the boiler.
    Also the construction of the internals after the plate is removed concerns me, I am not sure what to expect
    from the thermostat, and how the front plate will actually remove. So I was hoping that someone with
    experience could tell me whether I can DYI this, or if I should leave it for a pro.
    The boiler is a:
    Trianco Heatmaker
    Serial: 1093-1199
    Model: DBC-85
    Are there torque specs for the plate?
    Possibly the cause of the failure was over tightening?
    The gasket from the side, looks water logged:
    Front shot:
    Right side, not leaking:
    Thanks in advance!
    James
      File size:
      66.6 KB
      141
  2. jadnashua
    Can't answer your question, but I had a Trianco Heatmaker (different model), and finally replaced it because it was so much of a pain to keep running. It was the Heatmaker II, with the domestic hot water built in.
  4. jmacl
    jmacl New Member
    Jan 27, 2013
    RI
    Yeah, I am getting that feeling that it might need more maintenance than it's worth. I need to finish the season out with it, and I think it will make it, but if it was a 4-6 hour job I would probably do it. Anyway, thanks for the input!
  5. jmacl
    jmacl New Member
    Jan 27, 2013
    RI
    Well it turns out it should be fine for the rest of the season. I was told to just tighten it up, and it will last, but I should have someone out to work on it once we are not longer heating.
Similar Threads: Boiler Front
HVAC Heating & Cooling Adding a Zone to a Boiler Jan 9, 2017
HVAC Heating & Cooling Thermocouple for older boiler Nov 3, 2016
HVAC Heating & Cooling Advice new boilers for two apartment home. Jan 19, 2016
HVAC Heating & Cooling Boiler size question Dec 21, 2015
HVAC Heating & Cooling Oil boiler leaking fumes/smoke? Owner insists on NOT calling professional Pictures inside. Dec 15, 2015
