Boiler Flue Vent Connection Question
Discussion in 'Boiler Forum' started by cydown, Sep 21, 2009.
  1. cydown
    cydown New Member
    Sep 21, 2009
    CT
    Hello. I recently replaced an old FHW boiler in my house with a new Weil McLain WTGO-3. I had it inspected by the town and the only comment the inspector said was that the vent to the chimney flue was not allowed to have a reducer in the path and that the vent pipe should be the same diameter all the way to the flue connection. I can't find all the municipal codes of course but has anyone heard of this?
    The WTG0 series has 7 in. collar on all models but also states that the minimum breeching diameter for the WTGO-3 is 5 in. The current setup has the 7 in. vent leaving the boiler and has a reducer to 6 in. with one elbow in the path. The path is in total about 5 feet before reaching the flue. From my understanding and talking to Weil-McLain directly this vent configuration appears acceptable as it is above 5 in. and should not any back pressure scenarios. I am actually using the same configuration that was on the old boiler which was a little larger in BTU and it lasted almost 40 years.
    Is something else I am missing? Do I have any hope of changing the inspector's mind?
  2. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    I have no idea about your actual code but up here in BC we are allowed to reduce (when acceptable by the mfg.) right at the exhaust connection on the appliance. In other words the 7x6 reduce would have to be screwed onto the appliance it served.
    Do you have a picture?
  4. MAoilTech
    MAoilTech New Member
    Nov 24, 2009
    Oil Tech,HVAC
    MA
    it should be @ the chimney or @ boiler and not on the run so have a thimble in the chimney then ur reducer / increaser then ur flue pipe but each state town's has they own rules.
Similar Threads: Boiler Flue
Boiler Forum Properly venting a Wei-McLain CGi-4E boiler into a flue? Jan 28, 2010
Boiler Forum Flue liner size for boiler? Sep 16, 2009
Boiler Forum Classic Fanned Flue Gas Boiler SE18 FF Sep 11, 2009
Boiler Forum Weil McClain cga6pidn boiler Mar 17, 2017
Boiler Forum An American Standard Gas boiler Mar 13, 2017
