boiler 200000 btu
Discussion in 'Boiler Forum' started by jhon11, Sep 4, 2013.
  1. jhon11
    jhon11 New Member
    Sep 4, 2013
    Ontario
    hi, I have to replace an old gas boiler for a commercial property it's about 230000 output btu , what would be my best choice and what would be the price.
  2. jadnashua
    This is such an open-ended question. Just like in a house, before you arbitrarily replace the thing with the same size, you need to do some analysis as to what the right size is. Now, it's possible it was the right size, but that seems to be by far the rarity. It may be that the place could be well served with a much smaller boiler, with a smaller upfront cost and on-going fuel costs, along with being more comfortable. But, without knowing more about the building, it's radiation types, zones, insulation, design-day temperatures, insulation levels, windows, etc., there's no way to say. Then, throw in most (by no means all) people on this forum are from the USA, and not all products available here are available there, it makes it tougher.
    But, first thing, before just replacing with the same sized equipment, pay someone to analyze your actual needs and start saving some money.
  4. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    I have to replace an old car that puts out about 130 horsepower, for use on highways.
    What would be the best choice, and what will it cost? (And what if it has to be blue?)
    Seriously, the system it's going into and loads it's supporting matter. What Jim says is true- to come up with a satisfactory answer requires a lot more information and analysis.
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Nah, the first question is always " how much money ya got? " lol
  6. jhon11
    jhon11 New Member
    Sep 4, 2013
    Ontario
    ok thanks for the replies, I understand there are a lot of factors involved, nonetheless the boiler has to be replaced and I will have to choose a brand the guy that's going to install it recommended Lara's Weil McLain. or he said let me know if you would prefer any other. I was kind of looking for any reviews on boilers, maybe see which we're more reliable etc. well thanks for your replies if I do get more info I will post it.
  7. Tom Sawyer
    Nov 29, 2010
    Maine
    Ok, lets assume that a proper heat loss has been done and the heat load is indeed 200,000btu/hr. you could go with a single pass cast iron boiler, which would be the least expensive and least efficient choice. Of the lot, Weil McLain is certainly a stout and worthy choice as would be Burnham, Peerless, HB Smith and a host of others of their ilk. Taking it up a notch would be a 2 or three pass cast iron boiler say a Biase or a Buderus, both of which are fine pieces of cast iron with better efficiencies. My choice though would b to step fire a couple of mod cons with outdoor reset so that in the warmer months, only one boiler needs to operate. It really all comes down to cost v payback.
  8. gennady
    gennady New Member
    May 24, 2012
    Installing high efficiency heating and cogeneratio
    Brooklyn, New York, United States
    Find qualified installer with good track record and references, and he will guide you trough whole process. Just place price issue at #5 in your priorities list in this project.
  9. BadgerBoilerMN
    BadgerBoilerMN Hydronic Heating Designer
    Mar 4, 2011
    hydronic heating designer/contractor
    Minneapolis
    Ask for a heat load analysis. This will eliminate 9 of 10 heating contractors and leave you with the smart guy. He will know the best boiler for you to operate and him to service...annually.
Similar Threads: boiler 200000
Boiler Forum Boiler firing without call for heat on cold start Sunday at 6:17 PM
Boiler Forum Weil McClain cga6pidn boiler Mar 17, 2017
Boiler Forum An American Standard Gas boiler Mar 13, 2017
Boiler Forum Boiler slowly fills Mar 7, 2017
Boiler Forum Should I replace ~70-year-old boiler? Mar 5, 2017
