Body Sprays in Shower
Discussion in 'Shower & Bathtub Forum & Blog' started by Frankie, Mar 5, 2008.
  1. Frankie
    Frankie New Member
    Mar 4, 2008
    I am remodeling our bathroom and am installing one of those multi-function shower fixtures. My question deals with the body sprays. I am installing 6 body spays total. I have a thermostatic valve and a 3-way diverter with 1/2 inch. inputs. With 6 body sprays, I have concerns about layout and there being enough water pressure to power all 6 body sprays at once. All pictures and diagrams I see show only a maximum of 3 body sprays and they are in a vertical position. My wife and I would like to install 2 body sprays to the right of the thermostatic valve and diverter in a vertical position, 2 to the left of the therm. valve and diverter in a vertical position, and 2 on the back wall in a vertical position. Is this position layout possible and will there be enough pressure to feed all 6 sprays at once? If not, any advice is greatly appreciated as to how I can make this work.
  2. jadnashua
    Read the valves flow rates at the available pressure you have...1/2" probably isn't enough. Body sprays often aren't the same as a showerhead (limited to 2.5gpm), but can be in the order of 1-2gpm. Add up everything you want, compare to the valve's capacity and you may find 3/4" inputs may be required, not counting the huge WH requirements.
  4. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Six Body Spray Heads - Balancing Loop
    Great Question.
    I recently tried to wrap my head around a six body jets system.
  5. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    If it helps anyone I started another discussion on this same subject. Hoping the original poster might get an email flag and share with us his/her feedback.
    Once I finalize the layout I'll showcase how I pipe these six body jets together.
    New discussion on Body Jets Placement here
Similar Threads: Body Sprays
Shower & Bathtub Forum & Blog Most rationale approach to multiple showerheads, and bodysprays? Jan 23, 2013
Shower & Bathtub Forum & Blog I'm renovating my master bath+want to install mult shower heads and body sprays Sep 13, 2012
Shower & Bathtub Forum & Blog Does this quote make sense? Dual Shower w/ Body Sprays Jun 13, 2012
Shower & Bathtub Forum & Blog Mounting Delta body sprays & wall mount shower spray on Sterling Accord tub wall Mar 8, 2010
Shower & Bathtub Forum & Blog Plumbing Kohler water tile body sprays Jan 9, 2009
