Blue Angel Sump Pump - BCAP50
Discussion in 'Pumps and Tanks Well Forum & Blog' started by soccer123, Apr 7, 2009.
  1. soccer123
    soccer123 New Member
    Apr 7, 2009
    Does anyone have experience with a Blue Angel Sump pump - BCAP50 1/2 hp cast iron sump pump. It has a intelli-sense switch that is microprocessor controlled and has a 3 year warranty (not 1 year as many others). I have just purchased one and like the pump better than the Zoeller that it replaced.
    http://www.blueangelpumps.com/products.aspx?pr_productid=141
    thanks
  2. carmel corn
    carmel corn New Member
    Oct 14, 2005
    If I'm not mistaken, Blue Angel might be made by Wayne (or vice versa). Sorry, but I am not a fan of their products. They're better than Simer/Flotec, but not as good as Zoeller or Hydromatic brands.
  4. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Just because a pump manufacture does not give a longer than 1 year warranty on their pumps does make them inferior. Just as if they offer a 3 year warranty does not make them superior.
    The key to any decent pump system if the proper sizing of the sump pump pit. The pump pit should be sized in a way where when you have peak water incoming to the pit it should give you approximately 3 to 5 minutes between pumping cycles. I have customers that have pits that are under sized and need to replace their pump every 2 - 3 years, they figured to go with a 3 year warranty pump and been replacing it every 90 days. They went back to a Hydromatic its going on 120 days with out issue. I told these people they need me to tear up the floor and install a proper sized pit. It cycles every 45 seconds to a minute during heavy inflows. I have other customers with properly sized pits where the pump will turn on every 5 minutes like clock work. The pumps have lasted them 14 years, with new switches every 3 - 4 years. They are using Hydromatic and one is using a Zoeller pump.
    A Flotec would last a while if it was working in a properly sized sump pit.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Yea, I'd say it would last a little while....
    No where near as long as a good pump...
    As far as the Blue Angel...
    [​IMG]
    vs, Zoeller 50 series 1/3 hp.
    5' 43GPM
    10' 34GPM
    15' 19GPM
    Looks like a lot higher GPM...
    How big is the pit and what is the cycling frequency?
  6. SewerRatz
    Nov 20, 2008
    Chicago, IL
    Hydromatic OSP50
    The stats on a Hydromatic OSP 50 is
    5' head = 60 gpm
    10' head = 55 gpm
    15' head = 45 gpm
    20' head = 29 gpm
    23' head = 10 gpm
    Lock valve at 25' head
  7. Redwood
    Dec 15, 2007
    Service Plumber
    I posted the Zoeller 1/3 hp because that is what I typically see in sump pits.
    Of course it does not compare well to a 1/2 HP pump.
    If a Zoeller 1/2 was installed the pump curve goes like this...
    5' 72 GPM
    10' 61 GPM
    15' 45 GPM
    20' 25 GPM
    I consider the Zoeller to be a quality pump...
    The important thing is matching the pump to your needs and application.
  8. soccer123
    Apr 7, 2009
    basin size and cycling frequency
    The pit is a standard 18" diameter by 24" deep. I am sitting on a lot of water partially because of a large basement (44' x 77'). At the bottom of the pit, The pump runs continuously. I have tried both the Zoeller 1/2 hp and the Blue Angel 1/2 hp. Near the top of the pit, the pump runs for 10 minutes and rests for 40 minutes. I purchased the Blue Angel because of the electronic switch - no moving parts. The switch is mounted to the pump but is a piggy-back configuration. The pumping range is less than the automatic Zoeller pump and is about 3 inches. I am now trying a VerticalMaster switch to gain pumping range.
    I am considering another sump pump basin and raising up the sump basin that I currently have which is 6" below the concrete floor. I would appreciate any other ideas that anyoue has.
    Thanks
Similar Threads: Blue Angel
Pumps and Tanks Well Forum & Blog Surfur odor / hot water- Refillable Cartridges- Big Blue Dec 5, 2015
Pumps and Tanks Well Forum & Blog Big Blue Filter Recommendations Jul 16, 2012
Pumps and Tanks Well Forum & Blog How to change the "BIG BLUE" carbon sediment filter??? Dec 27, 2011
Pumps and Tanks Well Forum & Blog Blue stain in tub. Not acid water. Electrolysis? Mar 2, 2009
Pumps and Tanks Well Forum & Blog Well water blues Jul 26, 2007
