Blown-in Insulation into Existing Wall
Discussion in 'Remodel Forum & Blog' started by MAD King, Mar 28, 2013.
  1. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    Hello,
    My friend and I had a discussion if it would be also possible to insulate the interior and exterior walls with blown in insulation through the attice.
    Normally you drill holes into the walls in the rooms. Can holes be drilled into the walls from the attic too and fill it with cellulose blown in?
    Thank you
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I think it is best to have an opening at both the top and the bottom of each stud bay, to make sure that it is being filled.
    I don't think anyone would try filling from the top because in most homes one would only have a few inches of space to work between the outer wall and the roof.
  4. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    Would make sense. And of course on existing outside walls you have already some insulation bats in.
  5. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Balloon-framed houses without top plates are easy to retrofit with blown insulation. If you're drilling through doubled-up top plates you have to keep the holes small enough to not degrade structure, which means you won't be snaking in a dense-packing hose. (In stud bays with batts it's usually possible and recommended to dense-pack over them, for superior air-tightness.)
    But first things first, what materials are in the wall stackup, starting with the exterior paint, all the way into the interior paint? (eg: Brick / 1" air cavity/ rosin paper / plank sheathing / studwall cavity / lath / plaster / foil wallpaper)
  6. Windows on Washington
    Windows on Washington Member
    Sep 25, 2012
    Exterior Construction
    Washington, DC
    Gotta know wall construction first before you change anything like Dana mentioned.
    If you change how the wall dries, the consequences can be disastrous.
Similar Threads: Blown-in Insulation
Remodel Forum & Blog Finishing Basement - Doubling the wall insulation Yesterday at 1:13 PM
Remodel Forum & Blog Walkout Basement Insulation/vapor Barrier Question - Pic Included Apr 27, 2016
Remodel Forum & Blog Basement insulation options Mar 2, 2016
Remodel Forum & Blog Wine Cellar Insulation Feb 18, 2016
Remodel Forum & Blog Basement floor & wall insulation with perimeter drain Jan 21, 2015
