Blowing Out Filter Tanks
Discussion in 'Water Softener Forum, Questions and Answers' started by Flipperman2a2w, Sep 14, 2011.
  1. Flipperman2a2w
    Flipperman2a2w Member
    Feb 25, 2011
    North Carolina
    I have a water softener, a Birm filter, and an acid filter in the garage of our vacation home that is not climate controlled. Summers get pretty warm and winters get extremely cold. The garage is really the only place I have room for these units, and I’m worried about the tanks freezing.
    I was thinking about getting an air compressor to blow the water lines out under the house, and I was wondering if anyone has had luck with blowing the water out of their filter tanks. I know the water can be siphoned off, but that requires me to disconnect and open the tanks (which is a major pain in the butt and somewhat messy).
    Once the water above the media is blown out of the tank, it doesn’t seem like you would be able to continue to press air through the damp filter media to completely clear all of the water?
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    It is one of the steps that is done on a number of summer places around here...Alaska..
    The first time for a tank with what ever media will do water and then air, Wait about 5 minutes and to it again this time there will be some water then air.. wait again for 5 minutes and repeat.
    The main key is waiting long enough and doing it often enough to blow the water out... if done right there will only be a little water left that should not break any thing.
    What kind of valves are on the 3?
  4. Flipperman2a2w
    Feb 25, 2011
    North Carolina
    Thanks so much- I believe I have Clack valves on the two filter tanks, and the water softener is a Whirlpool.
  5. Akpsdvan
    Dec 29, 2009
    Alaska
    It is going to be a bit of a challenge, but around the bypass un hooking the plumbing and then hooking or plugging the in with the air hose ...
    Think with a really large box to find a way that works for you to push the air out of the media tanks.
  6. Flipperman2a2w
    Feb 25, 2011
    North Carolina
    Is it possible to hook the compressor up before the two tanks and water softener and just blow the water through the plumbing lines?
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    That is one way to do it, I would put them all in bypass and then start with just one at a time.
    or close the second two and blow the first one, then close it and open the second one ..... and work through them one at a time.
    One way that done at the time of installation was ... ball valve-snifter valve-softener-boiler drain-ball valve. then at the end of the season .. close the valves and start the blow down with the system's bypass staying open.
Similar Threads: Blowing Filter
Water Softener Forum, Questions and Answers Does anyone know this filter? Monday at 3:20 PM
Water Softener Forum, Questions and Answers Best Water Filter for Low amounts of Iron, Magnesium, and Manganese Monday at 10:28 AM
Water Softener Forum, Questions and Answers Valves for twin tank (parallel) filter installations? Feb 18, 2017
Water Softener Forum, Questions and Answers Fleck 5600sxt quit softening after sediment filter change Feb 18, 2017
Water Softener Forum, Questions and Answers Iron threshold for dedicated filter Feb 5, 2017
