Blocked floor drain looks corroded?
Discussion in 'Drain Cleaning' started by stephced, Jul 20, 2010.
  1. stephced
    stephced New Member
    Jul 20, 2010
    il
    our basement floor drain is clogged with what looks like rust and rocks (concrete) and water just sits on the floor...not the average hair, slime and soap scum. Have you ever heard of this?
    At one point it would at least drain slowly. Now it won't drain at all. Trying to dig through it with a stick/pole gets us now where becuase the grit, water and rocks fall right back in like quick sand. Could the drain itself be falling apart? The rim seems corroded and broken and the water is rust colored. Seems like an auger wouldn't as much as some sort of vacum/suction would. Tried plunging it and that doesn't not work either. Is this a job for a professional?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Probably is...
  4. Alberto01
    Alberto01 New Member
    Feb 6, 2011
    Australia
    If you are facing problem with drain pipe blockage or anything similar like that then the best way is to look for the drain cleaning service providers available to help you out in getting the drain cleaned in an environmental friendly manner. So, if you are planning to get it cleaned then look for the service providers available online.
Similar Threads: Blocked floor
Drain Cleaning Cleaning blocked exterior drain line... Jul 30, 2014
Drain Cleaning Clearing blocked condensate drain pipe for AC unit Aug 13, 2012
Drain Cleaning Multiple drains blocked??? Jun 5, 2009
Drain Cleaning Blocked sewer gone bad Dec 23, 2008
Drain Cleaning Washer drain pipe blocked Oct 16, 2006
