bleed valve leaking
Discussion in 'HVAC Heating & Cooling' started by r lawson, Sep 6, 2008.
  1. r lawson
    r lawson New Member
    Feb 25, 2008
    new runtal towle warmer bleed vale leaks w/30 psi air test
    do these radiators incorporate a float ball inside also, actuated by the water level?
    thanks any help would be appreciated
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Are you saying you put 30lbs of air on the system?
  4. r lawson
    r lawson New Member
    Feb 25, 2008
    30 psi in the loop befor connecting to manifold
  5. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    You may have a vent with a hygroscopic disc and if so then yes, it will leak slightly on air pressure. If you have a float-type vent it will definitely leak with air pressure.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    After much research I found the answer in a copy of...
    "Common Sense" Written by Thomas Paine January 10, 1776
    The vent is designed to eliminate air from the system.
    Therefore it would be an entirely reasonable assumption that it would not contain the air pressure in the system during testing unless it was capped or otherwise prevented from doing its intended job.
Similar Threads: bleed valve
HVAC Heating & Cooling Where to add bleed valve? Oct 18, 2009
HVAC Heating & Cooling Bleeding radiators Jan 26, 2016
HVAC Heating & Cooling hot water boiler with zero pressure air in pipes - how to purge/bleed air Dec 4, 2014
HVAC Heating & Cooling Hydronic baseboard bleeding problem Oct 6, 2009
HVAC Heating & Cooling Bleeding zones in hot water system Dec 24, 2007
