Blank Pipe next to Pipe? Air chambers.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by MAD King, Aug 11, 2013.
  1. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    Hello,
    I am wondering why there are a separate pipes beside the pipes which go to the valves.
    I got that on every valve pipe in my whole house.
    What is the sense behind and do I need it?
    Thank you
  2. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    Those are air chambers meant to reduce watter hammer, but they are ineffective. In no time at all they are filled with water were and undersized to begin with, sort of an oldtime plumbing superstition. They don't do any good but they don't do any harm. I don't know what project is that caused you to open the wall, but it makes things easier to leave them in, leave them in. If it easier if you cut them out, cut them out.
  4. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    They are air chambers to reduce the effects of water hammer. They are probably full of water now and doing nothing. They make proper water hammer arrestors now that have seperate air chambers that cannot fill with water. If you completly drain your system down they will work again but will eventually fill with water again.
  5. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    That is my shower. I will leave that in. But under my bathroom sinks are the same. So it is save to leave it off when I replace the pipes.
    Thank you
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Your question was already answered twice, but perhaps a third time will help. They do no good, but they don't hurt anything. If it was mine, I'd cut them off at the tees and sweat a cap on the stub, but you can leave them if you want to.
  7. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    Can you recommend water hammer arrestors which are not too expensive?
  8. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    The way they were put in, Tee'd off the side like that, they will waterlog and stay that way. If they were Tee'd at the top so as to collect air they may have stood a chance of working.
  9. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    No, they don't work at the way there are now in
  10. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
  11. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    Thank you.
  12. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Really, the only place you need them are where you have fast closing solenoid valves, such as washing machine, dish washer, ice maker, etc..
  13. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    Oh, ok, so after replacing the old pipes I can leave that off and just put something like this for the washing machine and dish washer?
    [​IMG]
    The one on the left
  14. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    If you put in arrestors, install them outside the wall, not inside. When they fail you want them to be easy to change. If you haven't had a problem with water hammer and they aren't required by local code, forget them. You can always add them later if you need to. Why try to solve a problem you don't have?
  15. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    Like LLigetfa mentioned. I have only hammering with the washing machine and dish washer. Would the arrestor I linked in my previous posting work?
Similar Threads: Blank Pipe
Plumbing Forum, Professional & DIY Advice Thermal Blanket on Gas heater Oct 27, 2005
Plumbing Forum, Professional & DIY Advice sealing pipe through concrete Today at 11:26 AM
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
Plumbing Forum, Professional & DIY Advice Dumb, probably repeat laundry standpipe question Feb 16, 2017
