Bladder Replacment
Discussion in 'Pumps and Tanks Well Forum & Blog' started by TMULLEN, Nov 16, 2005.
  1. TMULLEN
    TMULLEN New Member
    Nov 16, 2005
    I Would Like To Know If There Is A Way To Replace The Bladder In My Gould Model Wm-6 Pressure Tank.
  2. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    Owner - R.L. Peeks Pump Sales
    So. Cal
    If there is a bolted flange on the bottom of the tank, then the bladder can be replaced.
    Ron
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Their is only one tank I know of that has that flange to change bladder like Ron said. The reason I believe it the bladder was not too good in the first place.
    Before trying to do this job, be advised that it is probably one of the messiest jobs your ever going to encounter. And it's not as easy as it looks.
    Do yourself a favor and buy a new tank. If you want one that will last a long time, go with either Flexcon or Well X Trol.
    bob...
  5. mrichi
    mrichi New Member
    Nov 26, 2005
    You'll need 1/2 a day to complete this. The old bladder has to be cut and yanked out. This will take a little time. Make sure you get the manufacturers replacement bladder. It will arrive folded up so that you can insert with ease.
  6. speedbump
    Jul 15, 2005
    Riverview, Fl.
    I am going to let you read an email I got today from a man who just replaced a bladder. You be the judge of whether you want to attempt it or not.
    bob...
    Dear Sir, in March We replaced the bladder in our 220 gal. tank. It worked fine for several months then I noticed that the water had a smell to it so I thought the other tank had went bad.When trouble shooting I discovered that the old bladder was fine and the new one was in fact the bad one. ( It appears to have a small hole in it) when we put new bladder in tank we rolled it up as tight as possible and only got it in after several attempts by putting vaseline on it. Was this an incorrect installation or just a bad bladder? What is the proper way to install a new bladder in a old tank? Thanks, Jim
Similar Threads: Bladder Replacment
Pumps and Tanks Well Forum & Blog Water presssure / bladder tank problem and fix Thursday at 12:36 PM
Pumps and Tanks Well Forum & Blog Possible to replace bladderless tank with bladder-type tank? Sunday at 6:02 AM
Pumps and Tanks Well Forum & Blog How to get water in to bladderless pressurized irrigation tank? Jun 7, 2016
Pumps and Tanks Well Forum & Blog Normal bladder tank behavor? Apr 22, 2016
Pumps and Tanks Well Forum & Blog Pressure switch differential, CSV and large bladder tank Feb 3, 2016
