Black Specks - AGAIN
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by foxhome01, Dec 16, 2008.
  1. foxhome01
    foxhome01 New Member
    Aug 21, 2008
    North Carolina
    I posted a few months ago about black specks we were seeing in our dishwasher, showers and tubs. Based on my research it seemed to have boiled down to either the expansion tank or the anode rod. We've since had both replaced. I even called our City Water and they said that they've had people over the years say the same thing and it was their expansion tank.
    Sadly, they seems to be back. I've noticed them in the dishwasher again. Same thing that happened last time - we'd randomly see them and then all of a sudden they were all over the place.
    I have no idea what else there is to do. Someone had suggested that perhaps it's the water itself and that maybe we'd need a filtration system. If that's the last option, is that honestly going to resolve our issue?
    What's the average cost?
    Any other recommendations?
  2. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    The first step is to have a chemical analysis performed on your water by a professional lab. Expect to $65+. Otherwise you are just guessing at the problem
  4. jimbo
    jimbo Plumber
    Do you have black nylon braided flex connectors on the water heater??
  5. foxhome01
    Aug 21, 2008
    North Carolina
    How would I identify that? Not sure what this is.
  6. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Does your water utility use chloramine as it's primary disinfectant? If so, the black specks could be coming from rubber washers, rubber gaskets, or the rubber diaphragm on an expansion tank. Chloramine attacks rubber.
  7. foxhome01
    Aug 21, 2008
    North Carolina
    I am planning to have someone come to the house to take a sample and have it tested. When this was originally looked into the plumber took a sample and sent it out. They claimed high levels of iron in the water and suggested that it's reaction with the anode rod was likely the cause.
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    And when you replaced the anode rod you put in a nice new magnesium anode rod? :rolleyes:
  9. foxhome01
    Aug 21, 2008
    North Carolina
    yep, we did.
  10. Redwood
    Dec 15, 2007
    Service Plumber
    Well if the black flecks are Magnesium Sulfide which is caused by your water reacting with the Magnesium Anode, You need to install an Aluminum Anode to stop the chemical reaction.
  11. foxhome01
    Aug 21, 2008
    North Carolina
    I went and checked the receipt and it was in fact an aluminum anode. So, I have a brand new aluminum anode and an expansion tank. Neither have seemed to fix my problem.
  12. Gary Slusser
    Retired
    If you have any braided SS flex lines, they are black rubber hose.
    IMO black specs have nothing to do with the anode rod or the type of anode rod.
    Do you have any black slime in the toilet tanks at or below the water line?
    Is there any odor in the water and if yes, what does it smell like?
  13. burleymike
    burleymike New Member
    Nov 4, 2008
    Idaho
    The water from my shallow irrigation well is full of iron and copper. Every year I get one or two sprinkler heads that loose pressure. The inlet screen will be all clogged up with what looks like coffee grounds. If you crush them they look slightly orange.
    A few years ago I filled the kiddie pool from this well. I dumped some shock in the pool and went to bed. The next morning the pool was orange. It was fun to clean up.
    After adding a chelating agent I had to vacuum out a bunch of tiny ornage and green beads.
  14. Probedude
    Probedude New Member
    Nov 25, 2008
    CA
    Just for reference, mine are not black hose inside but instead white/cream colored - like teflon or vinyl.
  15. Gary Slusser
    Retired
    Then get a water test for manganese. Galvanized pipe or nipples can cause black specs too.
  16. Gary Slusser
    Retired
    You should have the raw untreated water tested for iron and copper.
Similar Threads: Black Specks
Plumbing Forum, Professional & DIY Advice black specks in water filter Nov 21, 2011
Plumbing Forum, Professional & DIY Advice Two New Faucets - One Has Rusty Water, Black Specks Mar 7, 2007
Plumbing Forum, Professional & DIY Advice What is this black stuff? Yesterday at 6:28 AM
Plumbing Forum, Professional & DIY Advice Fired for hiring a black plumber Jan 4, 2017
Plumbing Forum, Professional & DIY Advice Black spots in tub - new house (2014) Dec 28, 2016
