Black Soot in bathtub from SharkBite
Discussion in 'Water Heater Forum, Tanks' started by supermattthehero, Apr 23, 2013.
  1. supermattthehero
    supermattthehero New Member
    Oct 13, 2009
    virginia
    I've been getting black soot coming out in the bathtub when the hot water hasn't been used all night. It doesn't appear to be broken-up rubber. It is very fine, black, and the large pieces will break up and dissolve if I poke them with my finger. It will smear on the tub.
    I have a gas hot water heater. Does this mean it's on its way out? It's been like this for months now.
    EDIT: I should add that I also get them in the bathroom sink. It is not limited to the bathtub.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    It is probably from the anode rod disintegrating. It could also be manganese but I doubt it.
  4. supermattthehero
    Oct 13, 2009
    virginia
    What do I do about it?
  5. hj
    It is magnesium sulfide, often caused by a reaction between the anode rod and soft water. Change the rod and try to flush the remnants out of the heater, which may not be possible.
  6. matrazar
    matrazar New Member
    Jul 17, 2013
    Houston
    I recently replaced my gas hot water heater 2nd floor above master bathroom.
    I now have black soot appearing in my tub. since this is a new tub I am guessing I have magnesium sulfide in the pipes is there anything I can use to flush this out and clean the lines?
  7. supermattthehero
    Oct 13, 2009
    virginia
    Update: The problem wasn't the water heater, it was the Sharkbite flexible water heater lines I had used. Replacing them with conventional flexible copper lines solved the problem. Here is a link to someone else who had the same issue:
    http://www.kcsr.org/showthread.php?t=84485
  8. Terry
    Aug 17, 2004
    So the O-ring on the Shark Bite flex connector failed?
    There is a lot of heat right off the water heater.
  9. JerryR
    JerryR Member
    Jul 27, 2011
    Florida
  10. poe
    poe New Member
    Mar 12, 2014
    I have the same problem but all of my lines are copper. Running peroxide through my tank cleared it for about a week. I pulled my anode rod to find it covered with a thick layer of the black slime.
  11. S.Smith
    S.Smith New Member
    Mar 11, 2015
    Georgia
    Hey everyone. I realize this post is almost a year late, but after I replaced my water heater about 2 years ago, using Sharkbite U3088Flex24 Flexible Connectors for both my hot and cold lines, I started having the same problem with black soot in my bathtub. I just replaced them with Flexible copper. I cut one of the sharkbite connectors open and it was, in fact, black rubber on the inside. The rubber was disintegrating into black, flakey pieces that, when rubbed together, further dissolved into a slimy greasy film. Exactly the stuff that was in the bathtub. Thought I would share. Good luck to all.
Similar Threads: Black Soot
Water Heater Forum, Tanks black sooty stuff - anode rod? Sep 12, 2011
Water Heater Forum, Tanks Small Black Spots in Water Jan 16, 2017
Water Heater Forum, Tanks Black/Grey dirt out of new faucets Jan 6, 2017
Water Heater Forum, Tanks Black residue around water heater roof vent Aug 1, 2016
Water Heater Forum, Tanks Black inky coating in copper flex pipe on hot side? Apr 20, 2015
