Black poly tubing for potable water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by leak_chaser, Oct 27, 2013.
  1. leak_chaser
    leak_chaser New Member
    Aug 24, 2013
    South Carolina
    How can I tell which black poly tubing is for potable water and which isn't? Which rating/certification do I look for? The Home Depot website does not state in plain English if the tubing is for potable water or not.
    Thanks.
  2. leak_chaser
    Aug 24, 2013
    South Carolina
    This is for an underground line from the meter to the house.
    Not sure what you mean by formulation.
    Here is a few links:
    This one has no certifications or listings:
    http://www.homedepot.com/p/Advanced...300-ft-Polyethylene-Pipe-4-75200300/203013666
    This one is DWV rated and NSF listed (whatever that means):
    http://www.homedepot.com/p/Advanced...Poly-Pipe-2-75200500/203294164#specifications
    This one is NSF listed:
    http://www.homedepot.com/p/Advanced...ethylene-160-PSI-NSF-Pipe-2-1160100/202967364
    I tried the manufacturer's website but no luck.
  4. Terry
    Aug 17, 2004
    NSF listed. 200 PSI
    If it's a 2-3 bath, 1" will do depending on distance.
  5. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I would not use that kind of tubing for your application , if it is approved or not.
    Plenty of sand may let it work for awhile.
    I would not cut corners on your install.
    Daddy Terry knows best.
  6. leak_chaser
    Aug 24, 2013
    South Carolina
    Thanks. But what would you use?
  7. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Something rated over 160 PSI.
    Schedule 40 PVC would be my choice.
    That 1 inch that you listed is not all that great.
  8. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    If you are running underground from the well or city water main you want 160lb rated poly. Around here, thats pretty much all we use, including the city water departments.
  9. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That is some pretty thin stuff.
    I guess the city water department would like to use it. You Pay for the leaks and keep them in work digging it up and replacing it.
  10. Tom Sawyer
    Nov 29, 2010
    Maine
    Its actually pretty thick stuff and if properly bedded it will never leak. Its the same stuff we hang submersible water pumps on.
  11. hj
    quote; including the city water departments.
    Our local paper just had a picture of some water department employees removing the poly supply to the meters and changing to copper tubing. So it seems it is NOT the panacea that everyone thought it would be, but then that has happened with a lot of plastic piping over the years.
  12. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Yesteryear's 160-psi poly has become today's 200-psi poly, by way of newer high-density resins. The old 160-psi poly made from medium-density resin is still available, but is mostly used in wells, for submersible pumps.
    The key for potable water usage is the NSF-Rated labeling, insuring that all virgin resin went into the manufacture of the poly.
    Buried as shallow as it figures to be in South Carolina, I'd consider sch 40 PVC instead, unless they got some good reason not to use it.
  13. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    Use 160 or 200 psi poly from a reputable manufacturer like Charter Plastics, bed it in sand and be done with it.
  14. Tom Sawyer
    Nov 29, 2010
    Maine
    Agreed. I NEVER use PVC for water supply, either below or above ground.
  15. hj
    Quote: I NEVER use PVC for water supply,
    Around here PVC is about the only thing that is used.
  16. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    I don't have experience with any of this. I found this article of interest: http://www.usplastic.com/knowledgebase/article.aspx?contentkey=782 --in particular, the discussion of thermal expansion and contraction. They seemed to only be worried about it for when the cement was not totally hardened, but I wonder if some consideration would make sense for long runs over the long term.
  17. Wet_Boots
    Mar 23, 2007
    Metro NYC
    Obviously, answers relate to climate and burial depth.
    If I had one best shot at a shallow house supply going by tree roots, I'd use galvanized steel as a sleeve for a plastic pipe.
  18. craigpump
    Apr 12, 2012
    Reach,
    I have been using hydraulic cement for decades but i have seen some guys use silicone.
    I think the concern over thermal expansion is more important in geo thermal applications where the piping does expand and contract more than in a domestic water well application. For geo thermal installations they use LinkSeals to get a positive seal regardless of pipe temperature.
Similar Threads: Black poly
Plumbing Forum, Professional & DIY Advice ABS to Black Poly Pipe Connection May 14, 2012
Plumbing Forum, Professional & DIY Advice What do I have? Black poly with aluminum tube liner. Oct 29, 2010
Plumbing Forum, Professional & DIY Advice Tip on Wrangling Black Poly Coil Oct 2, 2009
Plumbing Forum, Professional & DIY Advice Copper to Poly (black PE) transition Jun 12, 2008
Plumbing Forum, Professional & DIY Advice Black Polyethylene water main Dec 2, 2004
