Bio Additives/Enzymes for Septic Tanks
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Mike50, May 11, 2006.
  1. Mike50
    Mike50 DIY Senior Member
    Jan 8, 2006
    Southern California
    I'd appreciate it if anyone can make a recommendation about additives.
    I have not emptied my septic for 6 years which I'm pretty happy about.
    Many people will swear by their favorite additive to maintain a healthy system.
    I'm skeptical and would really like to see some solid research that these products are effective enough to justify the up to 20 dollar price tag.
    It sems a lot like the cheap gas additive/cleaners-do we know they work?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Don't be to happy over the fact you haven't pumped your tank.
    You think you saved $$$ but not pumping on a regulsr basis is the worst thing you can do. It will shorten the life of the leach field by letting things go to it that shouldn't. Have it pumped, then use the additives if you like.
  4. Mike50
    Jan 8, 2006
    Southern California
    Based on your expertise Cass..I'm going to make some calls and look into this. To be perfectly honest, I have never heard that before from anyone/neighbors who have lived here for quite a while. I only hear about it when
    their tanks are full and *must* be pumped.
    I live in a very desirable rustic community near Palm Springs, CA. However
    I know for a fact that when these homes were originally built in the 70's-they did NOT use premium materials.
    I guess what I'm saying is that my instincts tell me that when I *Need* it pumped-it will in fact need replacing.
    I'm sure you can understand wanting to delay that expense...?
  5. Terry
    Aug 17, 2004
    Cass is right.
    It's much better to pump the solids out on a regular basis, and prevent damage in the first place.
    Pumping is a few hundred dollars.
    Drainfield replacement can run thousands of dollars.
  6. Mike50
    Jan 8, 2006
    Southern California
    Got it. Makes sense...
    I am curious about one thing Terry. When I have my tank pumped-is there anything diagnostic wise to determine the condition of the system to predict
    how many more years of use I can expect?
    It's not curiosity-It's all about managing finances and ear marking cash for something like that.
  7. Cass
    Cass Plumber
    Nov 12, 2005
    There is realy no way to dertermine the life expectancy of the leach field. It would be based on size, amount of usage, and frequency of pumping. That being said the average life is between 30-50 years.
  8. mariner
    mariner New Member
    Sep 23, 2005
    Millwright
    Hixon, BC
    Hi Mike,
    I am in a similar situation myself, however I know that my system has not been pumped in quite a few years (I recently purchased the property eight months ago) by the previous owner(s).
    When I first moved in last fall, after reading up on the myriad of different products, I decided to try Septic Seep. If their claims were legit., then it might help. I received the stuff and did a search on what the product was and found it to be basically a nitrogen fertilizer with a little something else added to it. I used it and have noticed a change at the start of the leechfield where there was a wet spot - it is now dry and the soil more like ordinary dirt instead of clay looking. Since then I have bought and used a nitrogen fertilizer a couple of times (46-0-0) to try and help the leechfield. I know I am going to have to spend some money on my system very soon - something I didn't know about when purchasing the property (rural). I thought a little help wouldn't do any harm at this stage. In fact I have someone coming on Monday to locate my tank and then we go from there.
    Over the years I have used different products in my septic tanks in the trailers I have owned. One in particular seems to work well and the tank actuallly smells much better for its use. The product is Septo-bac and is for septic systes as a whole. Don't know exactly what it does other than being bacteria and enzymes that are supposed to assist in the breakdown of the fecal matter.
    I have to agree with the comment about pumping out frequently for just a couple of hundred dollars at a time. Not pumping until something goes wrong is the expensive and shortsighted approach. When you "have" to pump, chances are you have left it too late and expensive work is looming on the horizon. I know I am going to have to shell out some big bucks because of the tightfisted approach of previous owners (I will be going after them for some adjustment as the system was said to be working well!!!! with no problems).
    Hope this helps Mike - I am learning a lot since buying this place and from what I have learned, there is no substitute for regular maintenance (in anything), especially septic systems.
    Mariner
  9. Mike50
    Jan 8, 2006
    Southern California
    Thanks for your post Mariner- I will make note of the additives and have now decided to do a "preemptive" pump because of the pro advice here. lol
    I will be curious to hear the pros comment on your situation.
    To date I have had no problems with my system for 6 years. It's my understanding that here in California escrow requires pumping/inspection of the tank
    prior to sale. The previous owner conveniently "forgot" to have this done
    before closing. It was discovered and she DID pay to have it pumped. (before escrow close)
    I also am in the country BTW. They call this area "Rustic" probably because it's very close to the big city.
    "Country" issues like septic tanks are a very small price to pay for the beauty and peace I enjoy. I'm sure you know what I mean. :)
    I don't know the laws where you live in B.C.----but it's not Kosher and not legal
    to inherit a badly compromised system here.
    Mike50
  10. Mike50
    Jan 8, 2006
    Southern California
    Alrighty. I made some calls regarding pumping/new tank information
    which was pretty enlightening.
    Regarding additives:
    Company 1:
    sells their own brand or recommends RID-X.
    Company 2:
    says do-not-waste-your-money. They are all useless as
    food and waste contain all the needed material (Bio-matter) to break this all down.
    They also reminded me to use liquid laundry detergent.
    No Kleenex or baby wipe products in system.
    Both firms are well known and here for years.
    They were also the company that replaced the lid on my tank in 1999 as it turns out. They informed me that I have a 750 gallon metal tank.
  11. vaplumber
    vaplumber Guest
    DO NOT BE HAPPY BECAUSE YOU HAVENT PUMPED YOUR TANK!!! 80 % of the biological action happens within the tank. When the sludge builds, there is less room in the tank to retain the sewage so that it can continue to settle and digest. What happens next is if you are lucky, the sludge will clog the baffle, and the tank will back up into the house. If you are not lucky as is the case most of the time, you will be pushing sludge and raw sewage into your drainfield which will soon fail. At this point DO NOT ADD ANY ADDITIVES to the tank. If you really do find something that works, and it does begin to break down what is already in the tank, then you will have a lot of loose junk in there escaping into your drainfield. If you want to use an additive, pump out the tank first and start your additive from the begining. My experience with them is even if you do use an additive and you pump your tank regularly, I have never noticed any reduction in the sludge and scum from the pre additive period, so do they work? Question of the day. Also to get an idea of your drainfield condition, if you have bright green strips of grass over it, it is on its way out. If that part looks fine, determine where your lines are, and use a post hole digger to dig a hole about 24 inches deep about 2 or 3 feet oout from each line. If the hole fills with water shortly, your field is saturated and is on its way out. If it doesnt fill with water, put the dirt back into the hole, and be happy that your drainfield survived your six year old sludge which you are hopefully removing from your tank. Best of luck. Hope I have been of help.
  12. Mike50
    Jan 8, 2006
    Southern California
    Thanks very much to all of you in this situation.
    I will be pumping this tank asap for sure and hopefully all is well.
    I do have plenty of green weeds in the general vicinity----whereas the other side of the property is relatively barren.
    **I live in high desert-my Lot is all sandy material and rock.**
    I also had a sink hole develop a little over a year ago (while it was raining in the winter). I don't know if there is a connection, but I think so.
    I'm also ready for the fact that my field may be on it's way o u t.
    I've asked people about septic tank issues around here....and I'm sorry to say that not one person ever mentioned maintainance pumping or I would have done this 2-3 years ago. damn.
    Nonetheless..it's my screwup and I'll deal with it.
    I'm not looking forward to the expense obviously BUT a "forever" concrete
    tank sounds pretty appealing.
    Oh BTW....even though this is desert-we are on a water table.
    I would hit water anywhere I dig.
  13. vaplumber
    vaplumber Guest
    I would hit water anywhere I dig.[/QUOTE]
    If you are on a high water table then your drainfield may be fine. My opinion is that the sink hole is not caused by this, rather is from the changing level of the water table from the rains. Your green weeds over your lines could easy be caused by the fertilizing affect carried to surface by the water table. I will say pump the tank, and because it is metal check it to make sure it is not rusting away, and then use it without worrying. If the drainfield is on its way out, you will know soon enough. It wouldnt hurt to save up to replace the tank in the future, but if the system seems to work fine, I would leave the drainfield alone. Metal tanks dont have a long lived lifespan. Some will live 20-30 years, many much less.
  14. Mike50
    Jan 8, 2006
    Southern California
    Well, Lid was replaced on 7/1/99 and home was built in 1977 so at least I know that IF the field is messed up it's not new by any strech.
    I'm getting someone out here as soon as I can.
    The company that replaced the Lid said it's possible the sink hole
    could be caved in Lid--but she was unsure about that.
    Sink hole is about the 18 X 10 inches and about 8 inches deep.
    I'm Very careful about what I put in my drains and toilet and it's just me here most of the time so maybe I'll get lucky with the field. Very little
    grease and food goes down my drain--I recycle everything thru my big ole desert dogs.
    Great Forum--Great advice as usual.
    If it wasn't for Terrys Message Board I never would have known how screwed up I am....lol
  15. Mike50
    Jan 8, 2006
    Southern California
    After sleeping on this and speaking with the contractor--it looks like I'm putting in a NEW tank.
    I'm leaning towards the concrete tank.
    I have material now that was mailed to me. This firm had the old service record.
    It's nearly 3X as expensive because of crane and so on and I don't mind that
    if it's going to last a "lifetime."
    Will it last 30+ years is my question? Any brands or designs to avoid if possible. Experience with root growth?
    Any other information about installation and features is appreciated.
    Cass-Terry-I owe you one for the original posts.
    For anyone interested I found this gem. If Im going to spend a few grand+ on this and live with it for 20 years--this book looks like good primer.
    It has the highest 5 star rating.
    small publisher direct:
    http://www.shelterpub.com/
    Mike50
  16. Cass
    Cass Plumber
    Nov 12, 2005
    It should last 30 years if installed correctly and you don't experience any direct hits from earthquakes. :)
  17. Mike50
    Jan 8, 2006
    Southern California
    LOL. I knew someone would say that.
    This place is nuts. 5 months ago I start posting here..right?
    Now I have an Aquia...A Dremel....and very soon a fancy 3 thousand dollar septic tank. It's not right I tell ya! :)
  18. vaplumber
    vaplumber Guest
    Mike, you are making the right choice. A concrete tank should last for 30 to 50 years and probably much longer. There are a few here locally that are going into their mid 60's and are in great shape. With roots, you should have no problem unless there is a leak. Roots only seek out moisture that they can sense, and will not bother the concrete if it doesnt leak. A good suggestion for you concerns the inlet baffle. The outlet baffle has a tail piece that extends down into the tank, but most installers here locally only use a simple pvc tee on the inlet. Ask your installer to add the tail piece extension to the inlet side. This will help prevent stirring of the septage as more enters the tank. You posted earlier that it is just yourself on the tank, and that you do not put certain things in your tank; in regards to this, your 6 years probably wasnt all that bad then. I would suggest pumping every four years, and if you add a member to your family, back it down a year. When you do your first pumpout of your new tank, your pumper can tell you if you are safe to go longer, or if you should service it sooner. If you have a disposer on your kitchen sink, I would suggest every two years. They create a lot of small particulate matter which is light and easily flushed into the drainfield. Best of luck with your undertaking!
  19. Mike50
    Jan 8, 2006
    Southern California
    Thanks. I will mention the tail piece extension. I have a 750 gallon tank now, and I wondering if I should upgrade to a 1000 gallon + or...? Are you familiar with
    the price breaks? I live on an acre so space isn't an issue here.
    M.
  20. Cass
    Cass Plumber
    Nov 12, 2005
    If you have the $$ a larger tank is better. It will give you more time between pumpings.
  21. speedbump
    speedbump Previous member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I have been on septics all my long life and never had any problems until I moved to this house five years ago. Pumped twice in 4 years because it completely stopped up with sludge. (Looks like soap scum) I also installed a new drain field.
    The pumper guy said a lot of the problem was using Charmin. He said Charmin and a few other papers don't break down like the cheaper brands. He said never put towlets, paper towels etc. in the tank.
    Years ago, I rented a cottage from my Grandparents. This place was 40+ years old. The soil was all sand and drained well. One day the toilet didn't flush, period; it just would not go down. I dug up the tank (after a lot of digging) and found a 120 gallon oil drum on end. I had to open the end with an ax. It had never been pumped. It also has no drain field. Ah the good old days.
    bob...
Similar Threads: Additives/Enzymes Septic
Pumps and Tanks Well Forum & Blog Septic tank. $200 down the Hole? Apr 17, 2016
Pumps and Tanks Well Forum & Blog Septic tank design Apr 6, 2016
Pumps and Tanks Well Forum & Blog Septic pump noise!! Sep 7, 2014
Pumps and Tanks Well Forum & Blog what is the best bacteria additive to septic system. Sep 2, 2014
Pumps and Tanks Well Forum & Blog Risers on septic tank - filter inspection lid Aug 10, 2014
